Old 10-21-2010, 05:37 PM
Default brake warning light/NJ
what is used to make a brake warning light ..to show brake failure...I'm going to title the car in NJ next year and they require this.
Jon
Old 10-21-2010, 06:04 PM
FWB's Avatar
FWB FWB is offline
Jon
i think that is just for ABS systems, i may be wrong but you may just need a parking brake light.
fred
Fred B
Old 10-21-2010, 06:10 PM
Jon
Jon, the one car I can remember that I owned that had non-power brakes and a brake light on the dash had a switch on the master cylinder that was triggered if there was low fluid in one of the two compartments. It would really only come on, as I recall, when there was an obvious brake problem and the pedal went to the floor -- so the light was next to worthless. If your master cylinder isn't wired for a switch, then what I would do (if your MC is visible) is just hook a phony switch with some wires to the bottom of it and label it "brake pressure warning light." If your MCs are hidden in a footbox then just run a wire in to the box and have the label right below where the wire goes in. Then just put a light on the dash and wire it to come on with the ACC position only.
Old 10-22-2010, 05:35 AM
Roscoe's Avatar
Now are you trying to say the NJ DMV people are DUMB nitwits????
Roscoe
Roscoe
Old 10-27-2010, 12:02 PM
All you need is a p valve with a sensor in it like the ones we used to use back in the day from the mustang 2. It makes a ground when you loss brakes.
Old 10-27-2010, 01:10 PM
I remember those lights. They came on 1 second before you hit something.
Old 10-27-2010, 03:29 PM
Cashburn's Avatar
Backdraft Racing Dealer
http://www.summitracing.com/parts/PRF-80174/
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
