Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
Old 02-18-2011, 12:05 PM
Cobra Make, Engine: A&C,351W
Default Caster adjustment
I have not taken things back apart to look but if the upper A arm is not slotted how can you adjust the Caster. I see people say that up to 3 degrees of positive Caster is a good setting for these cars but I am curious how that would be achieved on the tube A arms.
While on the alignment subject, a degree or 2 of positive camber is also reasonable. My car is finally reaching that point and I am trying to remember what I have been reading over the years.
Thanks,
Aaron
Old 02-18-2011, 12:24 PM
392cobra's Avatar
6th Generation Texan
Aaron...
http://clubcobra.com/forums/showpost...59&postcount=5
Even shims adjust camber without changing caster.odd number of shim change caster.The photos that Roscoe took will show you.
The link also contains the specs.
Old 02-18-2011, 02:03 PM
may be useful.....
http://www.crendonreplicas.com/crend...mber_gauge.pdf
Crendon 427, in the making
http://crendonreplicas.com/
