Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
Old 07-03-2011, 01:48 PM
Cobra Make, Engine: Contemporary Cobra
Default Noise Insulation
Would using open cell or closed cell foam have any benefit in reducing noise?
I want to insulate the rear wall behind the seats and the trunk?
Jon
Old 07-03-2011, 07:53 PM
Barnsnake's Avatar
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
Dynamat works nicely and doesn't consume much space. Its primary function is noise reduction.
Jim
A Gnat! Quick, get a sledgehammer!
Old 07-04-2011, 02:19 AM
PANAVIA's Avatar
Dynamat base with a foil lined jute pad if you have the space under carpet.
Old 07-07-2011, 08:05 AM
The open and closed cell will also fall apart due to the rubbing from expansion and contraction. Dynamat is the way to go.
Old 07-07-2011, 11:19 AM
Chaplin's Avatar
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Why bother? How much noise do you have coming through there? With sidepipes and an open roof I can't imagine there'd be any noticeable noise reduction from insulating the wall behind the seats and the trunk.
Replica is not a dirty word.
Old 07-15-2011, 07:46 AM
Cobra Make, Engine: A&C
Its worth it. I did the trunk and wall behind the seat. Also did the trans tunnel. More engine noise and less transmission gear and rear end noise.
ron
