Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
Old 02-27-2012, 03:19 PM
Cobra Make, Engine: Hunter - 427
Default A&C Weight
Has anyone ever had one of our cars weighed?
With a SBF if possible.
Thanks
Old 02-27-2012, 06:08 PM
Cobra Make, Engine: A&C Cobra, 521 CU BBF, Holley ProJection, T56 Magnum, 3.5:1 TruTrac 9-inch
actually yes, mine came in at 2576 pounds. this was on a four wheel scale with
LF = 683
LR = 647
RF = 567
RR = 679
Not sure why that right front has 100 pounds less weight though ?
Engine is 460/521 with aluminum heads,intake
Driving fast keeps you young. Just ask Einstein....
Old 02-28-2012, 03:16 AM
Default A tank
jbcobra67 Yes the weight is 2705 with 1/2 tank of gas in it.driver in car puts total package at 2975 with race gear. I don't have the corner weights in front of me. Battery is in trunk. Motor is all aluminum except for crankshaft, camshaft, rods, lifters, springs, keepers, valves, and connecting pins. weight on the 482 is 497 pounds. There are alot more cars with less weight but IMO not as solid in frame. Rick L.
Old 02-28-2012, 04:09 AM
Cobra Make, Engine: A&CAuto 460
Default A&C Weights
A&C 460,C6- Lf.650, Rf.650, Rr.640, Lr. 620. That Is Without Driver, And A Half Tank. Soon To Be An AOD. So This Will Change. Pat
Old 03-01-2012, 05:11 AM
Default Weights
Looks like 2 cars with 460 came in around 2560 or so. I did a search and it looks like the 302 base motor is about 175 to 200 lbs lighter.
I'm going to try to get it weighed soon. We had a mild winter and spring is near, now maybe the rain will go away and we can cruise.
Thanks for the info.
Joey
Old 03-01-2012, 12:56 PM
jerry w's Avatar
Cobra Make, Engine: Antique & Collectable 302, C-4,Ford 9 inch
Default 2360
2,360 pounds with a 302 a 200 pound driver and a full tank of gas
Jerry
Old 03-01-2012, 08:23 PM
Default Weights
That's a little lighter than I thought.
Thanks
Joey
