Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
Old 02-25-2016, 08:38 AM
Cobra Make, Engine: ac/428 pi
Default Need measurement from complete cobra with pan hard
Looking for a measurement from bottom of the upper frame to top of diff. With full load.
Old 02-25-2016, 12:05 PM
Cobra Make, Engine: Contemporary Cobra
Default Panhard Bar
You have a triangulated 4 link rear and shouldn't use a panhard bar it will cause the rear to bind and ride much harder
Jon
The Impossible Only Takes A Little Longer
Old 02-25-2016, 01:01 PM
So I should sell it? I bought it as a upgrade with my kit and see some guys have them.
Old 02-25-2016, 01:03 PM
http://i237.photobucket.com/albums/f...50/panard1.jpg
Old 02-25-2016, 03:57 PM
Thank you guys I am going to skip the pan hard bar.
Old 02-25-2016, 08:57 PM
Gaz64's Avatar
Panhard - one word, silent h.
Gary
Old 02-26-2016, 07:11 AM
PNJSNAK's Avatar
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
IMO
Are you using the solid aluminum bars or are you using the adjustable bars?
If you use the aluminum supplied bars the pan hard bar is not needed.
If you are using optional adjustable bars I would use the pan hard bar.
Let me tell you what happened to me.
I originally had the aluminum bars supplied with the kit. Drove the car hard for five years and then decided to put in the adjustable ones because I wanted to adjust the angle of the pumpkin.
Well, I took a corner real hard and broke the end of one of the bars and the rear end moved over. I fixed the broken end and repositioned the rear end and ordered a pan hard bar.
The idea of the panhard bar is to keep the rear end in a central position.
Therefore the position of the mount on the frame is critical to allow the rear to move up and down with any restriction.
I am not sure you can establish this point until the car is down on the ground and loaded.
I put the car on jack stands two up front on frame and two under the rear axle.
The took off the passenger tire determined best mounting position of the bracket.
Still drive the car hard on corners with no problems.
If A&C thought you shouldn't use a panhandler bar why would the offer it as an option.
I would call Joe T at A&C and ask him.
Jim
OhioCobraClub.com
Old 02-26-2016, 07:37 AM
I have adjustable 4 link bars and adjustable pan hard bar
Old 02-26-2016, 01:50 PM
Default Panhard bar
A&C does offer this option but it causes bind up and down. The upper control arms keep it centered. If your concerned about breaking a control arm then I would suggest replacing them with after market ones... They are not expensive.
Jon
Old 02-26-2016, 02:28 PM
I was looking at some with him joints and reverse thread so I don't have to remove one side and adjust them
