Old 08-20-2014, 05:34 AM
Default Charging system question
Having a issue with the charging system. 100 amp 1 wire alt and using a Tauras Fan for cooling. With the fan off the volt meter is showing 13 volts but with it on lately it is showing 11 volts and with halogen headlights on it's down to 10 volts.....motor is turning 26-2800
Rpm's. The car starts every time, had it checked out and by Advance Auto....they said it's ok Wonder if the fan is ready to go
so, any idea what's going on?
Jon
Old 08-20-2014, 06:19 AM
MOTORHEAD's Avatar
Double check voltage with a known good meter, such as a Fluke. You want 13.75-14.25 VDC no load.
You can also verify current draw with a clamp-on or induction ammeter and see the actual current draw of individual accessories.
"When Injustice becomes Law,
Old 08-20-2014, 07:57 AM
tcabece427's Avatar
Cobra Make, Engine: ERA
I assume the voltage regulator is separate from the alternator? If the it checks out ok by Advanced Auto then it is probably the regulator. The other thing could be if you have underdrive pulleys? It's less likely because it seems to charge at idle? Without the Fan and Headlights on.
Old 08-20-2014, 01:54 PM
Default Regular
It has a 1wire alt,never had this problem before
Jon
Old 08-20-2014, 03:39 PM
ffr 1137's Avatar
Cobra Make, Engine: FFR, 347, Massflow inj, 65 GT350 tribute
Weird...that's kinda what happens with a bad cell in batt...it won't take a charge. You did say it checked OK though. That's weird. Put a charger on it. Monitor before and after
voltage. I suppose it could be some excess draw. Fan on a relay though right, and fused?
Old 08-20-2014, 05:05 PM
Default Relay
No relay but fused
Jon
