Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
Like Tree1Likes
  • 1 Post By CoyoteCobra
Old 05-15-2021, 06:58 AM
Cobra Make, Engine: A&C, 2nd gen 5.0 Coyote, XAct Cromo light flywheel, TR3650, 3.25:1 LSD
Default Spring rates and coilovers
I'm curious if anyone swapped their rear coil overs on their A&C and if so what combination did you go with for springs and shocks?
My kit came with Viking coil overs on the front and I really like them. They're fully adjustable for comp/rebound and preload. They actually ride really nice and the handling is like a gokart. It is the rear coilover that the kit came with that I am not happy with- the spring rate is absurdly high and I've no adjustability in the shock. I think a softer spring and adjustability would help the car ride and handle better.
I've heard of a lot of people running QA1 on different builds but I'm not sure what spring rates were used.
Old 05-15-2021, 09:54 AM
jknich's Avatar
You can get Viking for the rear also. What rate are you running now? Most run 400-500 in front and 200-250 in rear. Measure your shock length at road height. Take one off and get the compressed and extended length. I like road height around 1" above mid travel of shock to prevent bottoming out. Get the right spring length for the shock also.
Jim Nichols
Old 06-07-2021, 05:46 AM
I'm not sure what the rates are now- they're whatever the kit came with. I will have to call A&C again to see if they can tell me.
Good advice on the shocks. If I can match some kings to the rear I will check that out. I think my current shocks have more than enough travel than I need as the rear will drop enough to cause a bind in my driveshaft before they stop. I had to add some limiting straps to keep this from happening.
jknich likes this.
Old 06-07-2021, 11:08 AM
QA1 and Viking share similar design origins.
I have a BBF engine with dual adjustable QA1's:
Front (A Arm) - QA1 Proma Star DD404 (2x) /Springs = 350 lbs. (2x)
Rear (Jag IRS) - QA1 Proma Star DD403 (4x) / Springs = 300 lbs. (4x)
At the same time, installed new Howe Racing Ent. ball joints.
Tracks the road solid like it's on rails now.
Old 06-07-2021, 05:43 PM
Cobra Make, Engine: Contemporary Cobra
Default springs
I ran 400’s up front and 180’s in the rear...bb motor, made a big difference in the ride.
Jon
The Impossible Only Takes A Little Longer
Old 06-12-2021, 08:55 AM
Thanks Salt and Unique. Unique - I don't have a jaq IRS so my rates are probably going to be much softer. I think a 460 is a bit over 200lbs more than a Coyote so I can probably run some really soft springs. I think I will try the 180s and see if that helps.
Salt - did you run QA1 on your A&C?
Old 06-12-2021, 12:16 PM
QA1’s on all 4 corners and NO Panard Bar… it caused to much bind! As a test with the panard bar on I measured how much the car would come down with a buddy sitting in the trunk and repeated it with the shocks and springs disconnect…. 1/4” difference. Reattached the shocks/springs and removed the pan hard bar and the car dropped 2” more.The Rear wasn’t moving with it. Made a big difference in the ride!
Jon
