Like Tree8Likes
  • 4 Post By Imlumpy
  • 1 Post By Chicagowil
  • 1 Post By PDUB
  • 1 Post By mrmustang
  • 1 Post By DanEC
Old 01-18-2023, 12:04 PM
Cobra Make, Engine: Antique and collectibles
Default Anyone else do this ?
So , I have an A&c car I bought from the persons who built it back in 2014. I felt it was a pretty decent looking car but the more I looked at the surface , the more I saw . So I got brave and ran a 12” sanding block across the surface , yikes ! It’s pretty damn lumpy . So I’ve been attacking the car , first 400 grit on a sanding block , then 600 on a d/a , then 800 , then 1000, then 3m super cut on a wool pad , then 3m rubbing compound on a form foam pad then perfect it glaze on a soft foam pad . It’s a lot of work but the results are , to me , how the car should look . I see a lot of comments on how great the A&c body is , in my case it’s far from what it could be , as delivered by A&c . Be warned tho , I wouldn’t recommend anyone dive in and do this , I owned a car dealership for 20 years and have above average experience with paint and body work .I should add , my car is a gel coat car , this would never work on a painted car , I can say , for what I see on my car , the gel coat is very thick , there’s a lot of thickness to work with .
Old 01-21-2023, 03:12 PM
Chicagowil's Avatar
That's a great looking finish! It's tough to make black fiberglass look straight.
Imlumpy likes this.
Old 01-21-2023, 10:54 PM
Thumbs up
Nice work! Well done.
Imlumpy likes this.
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
Old 01-22-2023, 05:45 AM
mrmustang's Avatar
Gold Star Contributor
Been there, done that
Bill S.
Imlumpy likes this.
Old 01-22-2023, 06:17 AM
hi, I am a new member and can't find out how to post anything? or how to contact, the directions are bad. sorry to bother you but I don't know what to do?? if you have time could you tell me what to do or who to ask??
thanks Jim
Old 01-22-2023, 06:59 AM
DanEC's Avatar
Looks really nice for polished gel coat. Yeah, handlaid or even old Corvette matching die/stamped panels are never going to match the latest composites or metal panels. You are a brave man - I had to go through the gel coat in several areas of my ERA to straighten out the panels and level panel match ups.
Imlumpy likes this.
ERA 782 Running
Old 01-22-2023, 03:47 PM
Thnx , it’s my winter project , one panel at a time , and unfortunately there’s still a lot of winter left .
Old 01-22-2023, 03:54 PM
Thnx , seems like on my particular car , the two lumpiest areas were the hood and the area between the trunk lid and the interior compartment. Tomorrow’s area will be the trunk lid , it’s not too lumpy but all around the edge , about 1 inch all around there’s a low spot . I asked a guy in the area who specializes in corvettes, it’s caused by the heat from the epoxies when they bond inner and outer panels together .
Old 01-22-2023, 03:58 PM
Bill S.
I suppose an A&c car in a lighter color gelcoat wouldn’t be so noticeable, but obviously a black one really shows it . All straightened out , it looks like a fine black paint job , nice and deep black. I like the idea of a gel coat car because it’s so durable and resistant to rock chips
