Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
Old 10-25-2004, 10:44 AM
Cobra Make, Engine: A&C- 351w 5spd
Question Part ID
I opted for the 11" front and rear disc kits. No problem with the fronts. In the rear kit, a package of brake fittings, fasteners and two steel blocks approx. 1"x1"x 1/4" thick with threaded hole. Anyone know what these are? I'm guessing, maybe something with the emerg. brake. Help, pls.
Jerry
Old 11-11-2004, 01:36 AM
Cobra Make, Engine: Antique & Collectible 351 windsor bored and stroked tko tremec
Hi Jerry these two blocks you have are they already welded on your rear housing? i believe if u check they are. i believe these two blocks hold the rear brake line hoses. it is also a tight fit when installing these lines. but any questions give a shout. Neil
