Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-24-2005, 06:15 AM
Default Quickstart Program/Rear suspension
I have FINALLY narrowed my decision down to A@C for my order. I am going with the quickstart program, and was wondering if anyone else has taken this route. Also, and recommendations for the rear suspension?
Old 07-24-2005, 08:37 AM
Send a message via AIM to mj_duell
A&C is a great kit. You are limited with the rear end and can only have a solid live axle. I would suggest getting the pan-hard bar option. My set up has it and it makes a world of difference under hard cornering. I would also up the rear spring rate to 350 lb coils instead of the stock 250 lb units. You will bottom the rear coils if you go with ant setting lower than suggested by A&C. I was able to get a nice ride and a nice low stance with the higher rate. The front springs are fine and did not need replacement.
P.S. You have a PM.
--Mike
