Old 04-10-2006, 06:31 PM
Cobra Make, Engine: A&C 351W
Default A&C Oil cooler
Does anybody have an oil cooler setup on their A&C Cobra? If so what cooler did you use? I have a 351 W in my A&C ,I just finished the car last year and I didn't put a oil cooler on it. I was also wandering what else I would need to hook it up (lines, remote filter ,fittings etc). I'm in the process of trying to finish up the front end, meaning in and around the rad and oil cooler area. I'm also trying to figure out some kinda way to put some alum flaring around the rad and oil cooler when I get one .Does anybody have any ideas?
Old 04-11-2006, 05:58 AM
Roscoe's Avatar
I got my Canton/Mocal oil cooler and shroud from Finish Line. Comes with the alum shroud. With the A&C you have to snip the lower corners off the shroud to get it snug. Since the below pic I've changed the lines to run opposed to one another. Also have the Canton billet remote oil filter adapter, CV remote filter and Canton Racing oil cooler thermostat.
Roscoe
Roscoe
Old 04-11-2006, 09:14 AM
Send a message via AIM to mj_duell
Canton/Mocal oil cooler and shroud from Finish Line, same as Roscoe.
--Mike / Turn Ten Racing, Inc.
