11-14-2009, 01:07 PM
need electrician
My sprinkler timer died. I bought another. However, this one needs an outlet.
anybody know a good inexpensive electrician.
11-14-2009, 02:24 PM
WHat ran the other one? Can't you use the same power source?
Dan in Arizona
CCX3209
11-14-2009, 03:06 PM
Call Rob Castillo. He is the landscaper Ken, Don, my son and I use. If the sprinker needs power he knows how to get it. 623-326-5198. Tell him you know us.
AZ Bob
11-14-2009, 05:08 PM
Mike,
You can use the same power as the old one.
Sounds like you just need to ad a outlet to the old wires or cut the plug off the new timer and hard wire it to the old wires.
Either way, make sure the power is off at the breaker before you mess with it.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
11-14-2009, 05:15 PM
Cobra Make, Engine: FFR from Levy Racing 302 FI w/Edelbrock Performer heads
Shutting the power off is for WIMPS!!!
Nothing like a little electrical shock to get your heart rate up.
dave from mesa
Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes. Finally got around to going to the VA.
11-14-2009, 06:39 PM
az
Cobra Make, Engine: FFR 30K mile driver
Throw an extension cord over the fence and use your neighbors power. Just a thought. Look on the inside wall for an outlet and then put a gfci on the outside after tapping into that outlet.
gary
11-14-2009, 08:57 PM
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Another thought if you didn't want to mess with the wiring is to getcha a cheap generator from Home Depot!
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
11-15-2009, 08:10 AM
az
Now that its cooled off, probably no need to do much watering.
You could probably put it off until March anyway.
11-15-2009, 06:11 PM
Can't use the same power as the old.
Thanks, BOB. I'll call him.
Nutty, Ginny say get it working. If Mamma is not happy, nobody is happy. And I cannot use dead ears as an excuse.
11-15-2009, 06:22 PM
Mikiec, I've always found that the best way to determine if the wires are hot is to lick my fingers before I touch one. Really, there's not much of an issue if you don't touch two wires at the same time, as long as you're not grounded, and everybody knows that you are not grounded.
Karlos
11-15-2009, 07:59 PM
[quote=mikiec;1001526]Can't use the same power as the old. QUOTE]
Yeah, Mikey, you are correct, there is an expiration on the power, just like in your tires and bean soup, prolly November 15th. Let the sh!t go completely empty and then put the new juice to her!
Ralph
Burma Shave
11-15-2009, 08:38 PM
Mike, I agree your old timer probably ran off of 110 volt and your new timer on 120 volts.
Totally different power sources.
FFR MK1---Sold
No more Furds.
11-15-2009, 10:37 PM
the old one.... Never mind.
11-15-2009, 10:53 PM
I'll put the outlet in for Mike! All you have to do is move to Tucson and consider it done!
11-15-2009, 10:58 PM
Larry,
Thanks for the offer. Now get your car done. I'm anxious to see and hear it running on the street.
