Old 11-20-2009, 08:45 PM
DWRAT's Avatar
Default Finally trunk supports.
Thanks to Tucson Jonh I got trunk supports.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 11-20-2009, 09:36 PM
mikiec's Avatar
With opening the trunk that wide Keep an eye on the external hinges.
Old 11-20-2009, 09:47 PM
DWRAT's Avatar
what do I need to watch for?
I could reduce the angle by installing the top mounts higher but I don't know if my shocks will support the angle.
FFR MK1---Sold
No more Furds.
Old 11-20-2009, 10:45 PM
DWRAT's Avatar
OK mike,
I took your advise and re-mounted the top mounts.
Now I need to get stronger shocks which I feel I needed anyways.
Now both my front and rear lids will sit at the same angle.
Dan
FFR MK1---Sold
No more Furds.
Old 11-20-2009, 11:04 PM
Cobra Make, Engine: FFR: 302 w/aluminum heads, Edlebrock injection. Street car trim, no scoop, side pipes or rollbar.
Send a message via AIM to Maricopa
Mikie I think that angle is OK on the purple cars.
"Cobra-Cobra-bo-bobra, banana-fanna-fo-fobra, fe-fi-mo-mobra...Cobra!"
Old 11-20-2009, 11:06 PM
DWRAT's Avatar
It's not purple, It's Rangoon Blue. A stock ford color from 1957 to 1969
FFR MK1---Sold
No more Furds.
Old 11-20-2009, 11:16 PM
Ahh Rangoon Blue, that was my 2nd guess.
Old 11-21-2009, 08:05 AM
vettestr's Avatar
Hey Guys,
Ya gotta admit even with all the back and forth that has gone on
" It's Rangoon Blue " is dam funny stuff ! jeff c
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 11-21-2009, 08:56 AM
DonMorse's Avatar
Hay,Dan Ratt i've been wanting trunk lid lifters from day one ,But i don't have very good luck when working with a drill around the Cobra as you must of heard .My question to you is how did you do it?. Ill be at 83rd tonight maybe you can bring it over so i can see how you did it.
Old 11-21-2009, 09:44 AM
Karl Bebout's Avatar
Rangoon Danr? U dere?
Karlos
Old 11-21-2009, 10:26 AM
mikiec's Avatar
Glad you moved the pivot points. The hinges were not designed to be at that angle. They could break.
Don not let Don near any car with a drill. Holes happen.
Old 11-21-2009, 10:35 AM
Or a big e'fn hammer! Or jack stands!
BTW, I've decided to start calling my paint, Rangoon Racing Green.
Old 11-21-2009, 11:09 AM
DWRAT's Avatar
OK, it's redone and wow It works well.
FFR MK1---Sold
No more Furds.
Old 11-21-2009, 11:13 AM
mikiec's Avatar
Much better
Old 11-21-2009, 01:33 PM
DWRAT's Avatar
Don,
I will show you and get you a parts list.
It is very easy and you will be able to do it no problem at all.
Dan
FFR MK1---Sold
No more Furds.
Old 11-21-2009, 01:42 PM
Don, the job will be much easier, in the garage, with the car up on jack stands or ramps. Be sure to keep the engine running and the struts will work better when you bump the tranny into gear.
Karlos
Old 11-21-2009, 02:10 PM
Famous last words. No problem at all.
AZ Bob
Old 11-21-2009, 02:52 PM
Danr55's Avatar
"RANGOON BLUE"? Wasn't that a Chrysler color in the 70's? Same color that they now call Viper Burple?
Dan in Arizona
CCX3209
Old 11-21-2009, 03:49 PM
mikiec's Avatar
Ratty,
When I get back from Puerto Rico I'll take a look at your setup.
Old 11-21-2009, 03:59 PM
Making your yearly trek back to the homeland Mikie?
