November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-06-2010, 06:47 PM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
Default Chucks Speed & RV Center
Anybody heard about this place (good or bad). Few of the guys that worked at B&R have moved over there since Bob Reams @ B&R have closed the shop.
Fitz
fitzus1@gmail.com
Old 04-07-2010, 01:12 AM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Yep Fitz,
Chuck's has been around for many years. I do not have a updated or first hand recommendation for you. I am not implying any negative thoughts simply have not worked with them at all in ten years or better.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 04-07-2010, 08:34 AM
mikiec's Avatar
If it is the same shop I'm thinking of, I used to work with Chuck at the old Phoenix American Jeep dealership on Camelback and 16th st. That was in the late 70's.
He was, at that time, a very good mechanic who took pride in his work.
Mike
Old 04-07-2010, 09:10 AM
vettestr's Avatar
Mikie,
It makes sense you did work with Chuck as the shop has been around for years. Anymore I am just so resistant to recommend places because you put your own butt on the line in doing so and then own problems real or perceived.
It always makes a big difference who's eyes you are viewing an issue through for sure. I always cringe when asked who to use for 3 common questions. I hate the who does car painting - upholstery and chrome question.
Jeff Classic
Old 04-07-2010, 09:41 AM
mikiec's Avatar
Jeff,
A agree.
I just checked, It is not the same Chuck I used to work with.
Mike
Old 04-07-2010, 10:50 AM
ItBites's Avatar
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
I used to take my BBC stuff to chuck 18 or so years ago. At the time I think he was certified to machine the ferrari stuff, for whatever thats worth... I never had any issue with his work and the 454 in my 12 second vette is 18 yrs old and the bottom end has never been out of the car (I did lose a Crane valve spring and had to pull the heads once, but that was Cranes fault for bad spring recommendation). He did the right things like match bearings to specific journals for optimal clearance, used torque plate during cylinder boring/honing, etc... So, I had good luck there back then, but have not used Chuck in many years (Been using Shafiroff in NY for my 540 stuff).
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
