Old 05-13-2010, 09:43 PM
mikiec's Avatar
Default Adding Relays summer project
OK,
Lets see those schematics of adding a relay to the following:
Fan 30 amp load
Lights
Fuel pump 15 - 20 amp
I also need to know what relay to use? Manufactures, model number and part numbers.
Old 05-13-2010, 09:53 PM
vettestr's Avatar
Mike,
I will hook you up with everything you need. I also have a 40 amp relay you may want to consider for the fan with a diode across the load to increase relay life. We can chat this weekend. Jeff
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 05-14-2010, 07:22 AM
I have some excellent wire nuts you can use. The are left over from my remodeling project.
Old 05-14-2010, 08:33 AM
Danr55's Avatar
Do they come with RING SEAL?
Dan in Arizona
CCX3209
Old 05-14-2010, 10:07 AM
DWRAT's Avatar
Mike,
Now that Jeff is clearly way to busy for us small potato people would you like me to work on your car?
I'm a pretty good hand when it comes to working on cars.
Here's a couple ideas for you.
Dan
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 05-14-2010, 10:59 AM
mikiec's Avatar
I've seen what happens to cars you work on. Almost as bad as Don.
Jeff, we will talk.
Old 05-19-2010, 09:22 PM
tin-man's Avatar
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Jeff, we will talk.
Wa, that's cold.......or was it a shot? tin-man
Be well, drive fast, live long
Old 05-20-2010, 12:00 AM
Danr55's Avatar
Hmm? Looked like a shot. Sounded like a shot. Reads like a shot. Why would you think it's a shot?
Dan in Arizona
CCX3209
Old 05-24-2010, 06:48 AM
How are those relays coming?
Old 05-24-2010, 07:52 AM
vettestr's Avatar
Hey Carnut,
I heard a vicious rumor you took a few hours out of your day to draw a schematic for our HMFIC. Actually I know you did cause I was lucky enough to get a look at it. Wow what a great job and kinda like the safety of redundant circuits you suggested.
Mike, with that data you are set. Let me know if you need any bailing wire or those twisty wire things. Jeff C
Jeff Classic
Old 05-24-2010, 01:22 PM
mikiec's Avatar
I have all the bailing wire I need, left over from my old Harley days. Plenty twisty things and bubble gum. I will need some additional wire seal and hole eraser.
You would think with him being a draftsman 'wanna be' he could have made a better drawing.
Old 05-24-2010, 02:32 PM
Danr55's Avatar
Mike, Can you use ring seal instead of hole eraser? You know, make them fit better instead of rubbing them out? I've heard a lot of guys in California do that and save big bucks.. Think on it.
Dan in Arizona
CCX3209
Old 05-24-2010, 04:37 PM
A better drawing would have only confused you.
Old 05-24-2010, 04:43 PM
DWRAT's Avatar
And cost you.
FFR MK1---Sold
No more Furds.
Old 05-24-2010, 09:12 PM
Dan would happy to help you, for free.
Old 05-24-2010, 11:04 PM
mikiec's Avatar
The next car Dan gets should, no, must have a sealed engine. Also, major warning signs under the hood... NO TOOLS ALLOWED.
Old 05-27-2010, 09:17 AM
Looks like you have plenty of help but if you need me to jump in just call.
Old 05-27-2010, 12:28 PM
mikiec's Avatar
Thanks Jerry.. I am good to go.
Just a couple of additional questions.
based on a 40amp draw.
1. Should the relay be mounted close to the switch or the device ie: fan?
2. What size wire do I need from the Battery to pin 30 and from pin 87 to device?
I'm guessing 12 to 14 Gauge.
