Old 12-28-2011, 04:02 PM
HighPlainsDrifter's Avatar
Question Firing order was wrong?
Hi,
Off hand I would check and see if the firing order was correct, roller cam is 13726548 and old 302 is 15426378.
That broken piston looks like it fired on the wrong stroke. The engine would run, just down on power.
Good Luck,
Perry.
Old 12-28-2011, 04:41 PM
RedSnake351's Avatar
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
N O T I C E ! ! !
The picture of the SINGLE BROKEN PISTON is NOT the one that came out of the engine this thread is about.
It was posted by HOTFINGRS and is out of a totally different motor!
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Old 12-28-2011, 05:27 PM
Danr55's Avatar
Perry, that's normally good info, but since Karl is running a Chebby, it won't help this time. I know, he's strange..
Dan in Arizona
CCX3209
Old 12-28-2011, 05:35 PM
Default Well that's the problem!
Chevy's are a different animal, it still wouldn't hurt to check the F.O.
Perry.
Old 12-28-2011, 07:44 PM
vettestr's Avatar
Karlos and Boys,
So what did you find or what are the strange things you found.
I know it is real easy to spend your buddies money but I might be able to help, give me a call.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 12-29-2011, 05:55 AM
dave from mesa's Avatar
Cobra Make, Engine: FFR from Levy Racing 302 FI w/Edelbrock Performer heads
Jeff
I think we are gonna pull the engine today. Not sure if we will have any info tho.
Everyone else:
Sorry if I didn't explain this is a Cobra that Karl wrecked about 3 yrs ago. He decided to keep it and rebuild it. 4 of us have been working a few half days a week for about 2 1/2 yrs. We have done just about everything from the frame up. We put the original engine, bored 454 chevy, back in it, It hadn't run all that time but seemed to run fine when we got it started up. All Karl has done is drive it around for maybe less than 100 miles when this happened. Sorry for the confusion.
dave from mesa
Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes. Finally got around to going to the VA.
Old 12-29-2011, 07:40 AM
vettestr's Avatar
Thanks Dave,
You may never find the turd that went through the cylinders but check in the intake and exhaust. I hope the left bank is not hurt any worse than what you already found on the right bank. A little solvent poured behind the valves will quickly check for bent valves. A new 540 or 572 would sure test all your suspension modifications. The 540 combo has been refined to a volumetric efficiency level that pump gas yields 700+ flywheel HP.
Jeff Classic
Old 12-29-2011, 07:50 AM
WardL's Avatar
What kind of gasoline are you using? Has the fuel been sitting around for 2 1/2 years?
Old 12-29-2011, 08:06 AM
It's a chevy engine?
Then, who cares?
Just kidding!
Old 12-29-2011, 03:30 PM
Fuel is new. Like I said he has drivin it a little less than 100 miles.
I agree about the Chevy but it is what it is.
The other head looks better but it is still beat up some. Gonna tear down the engine on Mon so we will see what other damage there might be.
dave from mesa
Old 12-30-2011, 11:28 AM
jetsbaby's Avatar
Carl.
If you guys ever need any welding done..Let me know..I do it for a living and I am cheap..Only a couple of beers for club members is the normal charge!
Old 12-30-2011, 12:47 PM
Karl Bebout's Avatar
Hey Jets, thanks for the offer. I'll certainly keep you in mind. Where are you located?
Karlos
  #33 (permalink)
Old 12-30-2011, 02:34 PM
jetsbaby's Avatar
We did meet all most a year ago at breakfast in Mesa..I had the black gelcoat F5 with the BBF 514 with the hard top..You probably remember..Me and China drove up in our cars..I am the retired Mesa PD officer..I live in Chandler AZ..I have Miller 252 mig and have the spool gun so I can weld aluminum with it..I also tig weld, but I don't have a tig welder yet..I don't want to buy a cheap Chinese one and Miller tig are a little pricey..
  #34 (permalink)
Old 12-30-2011, 08:16 PM
Jets, ya better keep Karl's contact info handy, if he ever gets his beast runnin' he'll be needin' a hell of a lot of welding services from ya!
Been told, he can't control all those chebby ponies under his hood!
Ralphie, the controller!
Burma Shave
  #35 (permalink)
Old 12-31-2011, 12:51 AM
Rick Parker's Avatar
Is it possible that some significant moisture got into some cylinders while it was sitting? I'm trying to read the gaskets and they may have failed while the engine sat allowing water to drain into in 2 or 3 cylinders.
  #36 (permalink)
Old 12-31-2011, 07:48 AM
tin-man's Avatar
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Hey Ralphie, dream on pal, you ain't the controller, yo' wifey is. Now go ahead and tell me I am wrong, I dare ya. tin-man
Be well, drive fast, live long
  #37 (permalink)
Old 12-31-2011, 07:53 AM
tin-man's Avatar
Why don't you talk Karl into putting a Roush engine in his beast and that would solve all his problems since there would be no guessing. tin-man
  #38 (permalink)
Old 12-31-2011, 08:14 AM
Hey Jets, I do remember you, now that you refreshed my memory. Haven't heard or seen anything from you in a long time. Glad you're back on line. If you'd like to send me a PM with your phone number, I can get in contact. Thanks, K.
Karlos
  #39 (permalink)
Old 12-31-2011, 09:58 PM
Danr55's Avatar
Tinner. That might get him a 100good miles.or so but what would he do after that?
Dan in Arizona
CCX3209
  #40 (permalink)
Old 01-01-2012, 08:02 AM
The #2 cylinder may have got cleaned by steam. In other words, a water leak.
Detonation seems like a good explanation. Have you inspected the plugs closely? There may be some evidence on them.
