Old 04-09-2012, 09:11 PM
Gofastoldguy's Avatar
Cobra Make, Engine: Factory Five Roadster
Default Radiator leak and exhaust problem
Before leaving Barlett Lake on Saturday you may remember my dripping antifreeze on the ground. Mike C was kind enough to give me a bottle of stop-leak to try. I also picked up an exhaust leak of sorts at the same time.
Got home OK and discovered a small hole in the top of the radiator cause by some abrasion of a bolt or something. I also looked over the exhaust system and discovered that the driver's side header was missing some bolts...like 6 out of 8!!
All this happening with 5 days before Don and I leave for AHA in Pomona.
Sunday was spent pulley radiator + shrouds. Monday went to the local radiator shop (Don's Radiator in Avondale) for the repair. It took 10 minutes and no cost to me. I then spent the rest of the day looking for the proper 1" header bolts. All in all a fun couple of days.
Hopefully I will finish tomorrow PM. What fun!
Bill B
Old 04-10-2012, 10:07 AM
Good going old guy. I knew you could do it. Have a great trip. May be some weather stuff ahead of you. Dress warm and stay dry.
AZ Bob
Old 04-10-2012, 02:17 PM
Wow, glad you got it fixed.
I suppose I should tell you about that other thing I saw Saturday.
_____________________
Old 04-10-2012, 04:19 PM
Danr55's Avatar
Nut, you're really bad.
Dan in Arizona
CCX3209
Old 04-10-2012, 05:25 PM
Car Nut...I know, it will cost me $200 to fix. LOL
Old 04-11-2012, 11:03 PM
Default Cobra repairs
Looks like I finally fixed all my faux pas' on the Cobra.
Header bolts when in w/o problems...with lock washers this time. Found another exhaust leak at the collector, one bolt was loose and causing some weird vibration noise.
The radiator problem was another thing altogether. After reassembling all the components and filling up with anti freeze, I encounter a fluctuating water temp guage. I went from 85 to 125 Celsius and back again. Went back to the radiator shop to pick some brains and found the water level was low again. Jimmy at the shop said this is a common problem with the Cobra Ford motors. You usually encounter a air blockage when purging the system. You have to keep filling the system frequently until the water temp stabilizes. I did this about 10-12 times until the temp settled down to the 85 degree normal temp. Drove a bunch today and no problem.
I was at the point where I was going to cancel the trip to the AHA show in Pomona Friday. Looks like we are back on again.
By the way, if anyone is interested in rooming with me at the SEMA show in October/November let me know so I can add their name...(Robert ?)
I'll take lots of photos while in Pomona and get them posted on Az Cobra site.
Ciao!
Bill
Old 04-12-2012, 05:45 AM
mikiec's Avatar
One thing to remember when working on the cooling system, you must purge all the air out of the system. Automechanics 101. LOL.
Glad it's up and running.
Enjoy your trip.
Old 04-12-2012, 08:06 AM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Default purge valve
Hi,
I put an air purge valve in the top heater line(a prestone backflush T).
It's the red T just behind distributor in picture.
You just fill the last 2 cups of water through the highest point and good to go.
Perry.
Old 04-12-2012, 05:03 PM
Default Purge valve
HPD...good idea but one must first have a heater/ac line to make it work. Sometimes I wish I had both in the car. Your Daytona is perfect for that. I just had to have some patience and it was OK. I never had a problem purging any air block in my previous non-Cobra life. At least I know what to do now. Thx for the tip though...
Regards, Bill B
Old 04-12-2012, 05:11 PM
Cobra Make, Engine: FFR MK-I, 302, 780 Pro-Systems custom double pumper, 425HP
I always carry a few extra header bolts with me on a long trip. They seem to like to fall out. Last time it happened it was on the Route 66 Fun Run.
Mesa Mike
Old 04-13-2012, 09:22 AM
two words for you guy's "SAFETY WIRE", problem solved or buy header bolt retainers
Old 04-13-2012, 03:57 PM
Lightbulb exhaust tip
Bill,
I haven't had an exhaust bolt back out for along time since I've done this;
I do not use an exhaust gasket as they compress and that causes the bolts to loosen up.
I put a small amount of copper silicone sealer around header ports after I run a file across them to make sure they are flat and have no burrs.
Tighten all the bolts evenly to about 30 ft/lbs, you can feel them tighten up as metal to metal there is no slack.
Good luck,
Perry.
Old 04-16-2012, 07:33 PM
Default Header bolts
Perry...thx for the advice. I was able to find bolts with lock washer included. I drove to Pomona and back and everything was at torque spec of 30#.
Bill
Old 04-18-2012, 09:34 AM
Check out this product they work great for header bolts and any other bolt that could come loose.
Products - Nord-Lock
Old 04-19-2012, 10:57 AM
Default Nordlock washers
I have use them for all my exhaust down pipe/J pipe and 4 bolt flanges. They are great and never a problem. If I continue to have any more manifold leak problems I'll use them.
Bill
