Old 09-01-2013, 12:28 PM
DrDuc's Avatar
Cobra Make, Engine: FFR1983, 427W, IRS, Wilwood brakes
Default Clutch problem
My clutch is doing strange things. Most of the time it's fine with take up mid-travel, but occasionally it engages just off the floor. I've had Gordon Levy look at it and it behaves for him. Any good ideas on the problem and the fix?
Bruce
Old 09-01-2013, 12:57 PM
Tom Cimino's Avatar
Cobra Make, Engine: Everett-Morrison 427SC 302 smallblock. 431 stroker in the works, tremec 3550
I had a problem like that once. Turns out the pivot bolt for the clutch pedal was a little too tight and wouldn't allow the pedal to move freely. I loosened the nut a bit and the problem went away. The nut was a nylock nut.
Old 09-01-2013, 02:08 PM
Danr55's Avatar
Is it mechanical or hydraulic?
Dan in Arizona
CCX3209
Old 09-01-2013, 11:12 PM
DrDuc's Avatar
Hydraulic
Old 09-02-2013, 12:22 AM
Gaz64's Avatar
Master cylinder internally bypassing.
When it engages early, does it then have a lot of pedal freeplay at the top?
Old 09-02-2013, 02:51 AM
Danr55's Avatar
Does it usually engage.early when you start out and its cold or is it truly random?
Dan in Arizona
CCX3209
Old 09-02-2013, 11:09 AM
DrDuc's Avatar
It is truly random and the pedal feels the same. No free play feel. It just engages at the very bottom. Some times it feels like the clutch isn't going to work at all and I won't be able to get the gears engaged. Then it engages half way up as usual and continues to work fine for 10-20 shifts.
Old 09-02-2013, 03:14 PM
Danr55's Avatar
I would look first at the clutch cylinder. Sounds like it has worn a soft spot in the middle and needs to be replaced. THat would be doubly true if it happens when you sit for a minute holding the clutch down. The fluid leaks around the piston.
Dan in Arizona
CCX3209
Old 09-02-2013, 04:12 PM
DrDuc's Avatar
Thanks for the input. I appreciate it.
Bruce
Old 09-02-2013, 04:27 PM
DrDuc, do you have a slave cylinder? Sounds like when mine died from seal leak. Just like what Dan said. Cheap replacement.
AZ Bob
Old 09-02-2013, 04:43 PM
James Stern's Avatar
Cobra Make, Engine: Classic Roadster, 302, roller cam, Holley 650
Check the cable.
The one line never heard in heaven; "Gee, I wish I had spent more time in the office."
Old 09-03-2013, 01:15 AM
Gaz64's Avatar
Master cylinder?
AZ Bob
Of course he has a slave cylinder. He could also have a hydraulic throwout bearing which is not cheap, gearbox out job.
Originally Posted by James Stern View Post
Check the cable.
What cable?, It's hydraulic.
Old 09-03-2013, 06:46 PM
DrDuc's Avatar
Well there are no leaks, the system has been flushed to make sure there is no air in the lines, so we'll check the throw out bearing next. Looks like maybe I'll through in a new clutch while it's all apart.
Old 09-03-2013, 06:48 PM
DrDuc's Avatar
Or throw in a new clutch, would be more accurate.
Old 09-04-2013, 06:09 AM
Danr55's Avatar
If the clutch cylinder is worn, it will only be at one spot. Try pushing the clutch all the way to the floor and see if it works. It's a lot cheaper to replace a clutch cylinder than a complete clutch. That is especially true since, if it is the clutch cylinder, you'll have to replace it anyway.
Dan in Arizona
CCX3209
Old 09-04-2013, 01:36 PM
Average Guy
Is the clutch fork staying positioned on the pivot ball correctly? Mine was worn and the spring steel retainer was sprung and the fork could move around, changing the relationship between the pivot ball and the socket on the fork. I replaced both the pivot and fork and it made a nice difference.
