Like Tree17Likes
Old 03-25-2020, 08:13 AM
Danr55's Avatar
Default Carburetors
Let's hear some opinions and preferences about carbs. Different makes or different models.
Dan in Arizona
CCX3209
Old 03-25-2020, 08:42 AM
Cobra Make, Engine: SPF GT40
QuickFuel 750 mechanical. Ability to change all jets especially idle fuel restrictor. Most Holley carbs have a fixed idle fuel orifice and it's too big.
Old 03-25-2020, 09:26 AM
Cobra Make, Engine: FFR, 347, 462 hp, 4 barrel
Quick Fuel 650 cfm on a 347 ci engine. Set up on dyno then final adjustments made with a O2 sensor in pipes. No choke also. I have not touched any adjustments in over FIVE years.
Lee
RedSnake351 likes this.
Old 03-25-2020, 09:58 AM
Karl Bebout's Avatar
I had "Pro Systems" build a carb for my Biggie Rat and was totally pleased. Bolted it on, set idle speed, and WOW! I even loaned it to my Buddy, Camaro Bob, and he liked it so well that he ordered one. There's an extensive info sheet to fill out and Patrick will build a carb specific to your needs. At the time it was maybe $100 more than a HiPo Holley off the shelf and so worth the money. Your asked, I'm telling. My 2¢ worth.
CJ428CJ likes this.
Karlos
Old 03-25-2020, 10:40 AM
jetblue69's Avatar
Cobra Make, Engine: ERA #816, 427 Side Oiler
I have a 850DP with mechanical secondaries and 4 corner idle I rebuilt myself. I did have Holley re-dichromate the carb since it was previously installed on my Chevelle big block car... I eliminated the choke and did the tuning myself (if you are not familiar there are a couple of books out there that have VERY good information). I understand that not everyone is a carb guru and that small businesses need to make money but I really try to shy away from paying for something I can do myself. I personally find that Holley carbs are VERY EASY to tune given the basic knowledge set. My main advice on the matter is, you can usually make a larger carb run smaller but not the other way around... within reason
Old 03-25-2020, 02:45 PM
I'm a Quick Fuel guy. Pretty much all I use.
Old 03-25-2020, 03:55 PM
Gaz64's Avatar
Holley Ultra XP 850, BLP Rapid Jet Metering Blocks, External PV referencing.
Constructed from all new parts.
PV opening point externally adjustable, all fuel and air metering can be changed without removing a fuel bowl.
ScratchBuilder and ront49 like this.
Old 03-25-2020, 04:12 PM
RedSnake351's Avatar
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Question
OK, Dan, what is the REAL reason for asking? Don't keep us in suspense!
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Old 03-25-2020, 07:25 PM
Phx Mike's Avatar
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
I have a Quickfuel 780 with the vacuum secondaries. Works great....
ront49 likes this.
Old 03-26-2020, 02:49 AM
mrmustang's Avatar
Gold Star Contributor
Spent days on a chassis (not engine) dyno with a virtually unlimited supply of carbs and came to the conclusion, bigger is not always better
Bill S.
Old 03-26-2020, 04:34 AM
8Ball's Avatar
Quick Fuel 850 DP no issues at all!!!!!
Old 03-26-2020, 04:58 AM
MKS427's Avatar
Cobra Make, Engine: FFR MkIV 427
I had a Quick Fuel 780 vs, it would not work well below 1800 rpm with a big cam, no carb will without steady vacuum. Ended up going with a FiTech 800 hp system. Little bit of a learning curve, but it runs smooth and compensates for altitude. Had to add 177 lph in tank fuel pump and a return fuel line.
Old 04-02-2020, 08:24 PM
Phx Mike's Avatar
My cam is not real big considering the size of my engine (482 ci)....cam is 242/248 at .050 with 112 LSA and lift at .642 intake and .631 exhaust. Installed 4 degrees advanced. Runs great everywhere even below 1800 rpm but I never run there. Likes 3000-6000 best. But....it is a carb so it runs rich at altitude and doesn’t like the cold and....
But it does work as well as any carb I have ever used...
Old 04-02-2020, 08:34 PM
Phx Mike's Avatar
No choke on mine either ... we don’t need no stinkin’ Choke.....it’s Arizona!
Dwight likes this.
Old 04-03-2020, 06:10 AM
undy's Avatar
I'm running twin Quickfuel 750s on my 482" KC side-oiler. I had Quickfuel custom build them exactly for my engine. On the chassis dyno they ran 14.7 AFR at idle and 12.4 AFR through the RPM band at WOT.
Cobrakeith likes this.
Too many toys?? never!
Old 04-03-2020, 08:08 AM
cycleguy55's Avatar
Holley 770 Street Avenger. Works well, once I sorted out the choke pull-off - when I got it the choke opened about 1/4 as much as it now does.
Brian
Old 04-03-2020, 12:35 PM
Danr55's Avatar
I got a Blykins built Quick Fuel 750Q from a friend for a song.. I think I'll be quite happy.
Dan in Arizona
CCX3209
Old 04-04-2020, 09:24 AM
Danr, who you gonna get to install the new carb for you?
You know things don't go well when you work on your engine
Karlos
Old 04-04-2020, 03:16 PM
Have a 850 mighty Demon very happy with it
Old 04-04-2020, 05:11 PM
Phx Mike's Avatar
Dan what happened to your old carb(s)? Why are you changing?
