Old 12-08-2006, 04:54 PM
Wolverine's Avatar
Cobra Make, Engine: FFR 4752K
Angry Beware the "plink...clunk"
When I was driving the car a little while ago, I noticed that I got a noise like a piece of gravel hitting the splash guard when the front end unweighted on the crests of hills (gotta love Pinnacle Peak road! ). Strange "plinking" noise that happened at least a dozen times. Now the last time I drove, the noise was working itself into a soft "clunk". I've checked and double-checked and nothing is loose that I could see. Very odd.
If anybody sees a red Cobra on the side of the road on your way to the party tomorrow, please stop and give a hand...
Old 12-08-2006, 05:09 PM
RNT's Avatar
RNT RNT is offline
Cobra Make, Engine: SPF #2457, Sunset Red/Titanium Stripes,460FR, SCJA, TKO 600
If you hear a sound like "ker-plunk", then you have a major problem..
"The Cobra is a 40 year old design that moves people like no other".
Old 12-08-2006, 06:48 PM
BPWilliams's Avatar
Cobra Make, Engine: none
I also hear that a "Tat, Tat, pew, pow" sound is not good either. If we see ya we will be sure to tell Hursh that you'll be awhile...
Cobra friends don't let Cobra drivers stay stranded...
There is No Replacement for Displacement.
U.S.A. All the Way!
Old 12-08-2006, 07:47 PM
Murphy's Avatar
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Default That's odd?
If you hear "Bada-Bing" stop and buy a lottery ticket.
Old 12-08-2006, 07:57 PM
Blittleton's Avatar
CC Member / Sponsor
Murphy,
I see that you have an FE with a Mass flo, how do you like it? I'm going to build me one soon for one of my customers.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
Old 12-08-2006, 11:55 PM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Murphy:
SInce I am considering putting a Mass-Flo on my FE as well I echo Bill's question. How do you like it and did you do the installation yourself?
DonC
Old 12-09-2006, 06:09 AM
Mulv's Avatar
Cobra Make, Engine: Cobra-less for now..
Warning!! Thread hijack in progress!
W you are probably hearing the shock mounts moving.. we better put this puppy on the lift at Hersh's and check it out...
It's under a big W, a big W see?
Old 12-16-2006, 03:31 PM
Wolverine's Avatar
Unhappy Found the plink!
I pulled the pass front wheel today and I think I found the cause of the noise. It looks like my coilover spring is deflecting and rubbing on the adjuster ring. If you look at the pics in the links below, the white areas are the wear areas. I'm not really sure what to do about this. I'm going to call FFR on Monday and see what they say.
http://members.cox.net/ccatt/shocks/shock1.jpg
http://members.cox.net/ccatt/shocks/shock2.jpg
http://members.cox.net/ccatt/shocks/shock3.jpg
Old 12-17-2006, 11:19 AM
mikiec's Avatar
Craig.. after you call them let us know what they said.
now back to the hijack.
Murphy.. I too would like to hear about your expericnce with the mass flo and the FE.
Mike
Old 12-19-2006, 08:54 AM
Wolverine's Avatar
Well, FFR's initial response is that this is normal wear. They said I should just grease the heim joints on my shocks and get drivin'. I sent them some pics to look at so we'll see if they have anything else to say once they check those out.
I guess I need to change my screen name to Mr. Plink.
Old 12-19-2006, 09:30 AM
Murphy's Avatar
Smile Mass Flow EFI
Sorry for the response time delay. The Mass Flow EFI is fantastic. EZ to install, well made, good instructions and the customer support from Chris is great. I put the system together and after talking to Chris because of my inability to follow clearly written instructions. I got the engine running and the final timing set in one hour. Half of the hour was wait time with the power to the computer disconnected to allow the module to reset itself as part of the process. I am putting together another car for a co-worker and from start to finish I put the entire Mass Flow system on the car in 2 days with only some minor wiring clean up to yet deal with.
Starts like a new car, you can reach in the car and turn the key and it starts immedietly. WOW.
Old 12-19-2006, 11:53 AM
Club Cobra Member
Cobra Make, Engine: B&B 408W, TKO 600, 9" 4-link Truetrac, 13" X 1 3/8" curved vane frt disks
Wolverine, this might be a common problem. I have the same issue on my rear setup with different car, different springs, different shocks.
Old 01-04-2007, 02:10 PM
Wolverine's Avatar
Well, after lots of back-n-forth with FFR, I've ordered a new adjuster sleeve for my pass front coilover. They're convinced that there's nothing wrong with the spring and it must have been cocked a little bit when it was assembled. I don't think so but it very well could be. I'm not a pro-builder so mistakes can happen.
We left it that I'll put everything back together and see how it goes. If in another 500-700 miles I have the same issue, then we'll look into replacing the springs.
DaveR - not sure if you're still watching this thread but if so, how many miles did it take for you to get some wear? They did say wear was common but not as severe as mine is and in the short amount of time that I've been through.
