Old 03-22-2007, 06:02 PM
rforrester's Avatar
Cobra Make, Engine: Factory 5. 94 Mustang Cobra 5.0 EFI
Unhappy grease leak from front hubs
I have driven my car about 50 miles and notice that grease is slinging from the insides of the front hubs.
I used the Ford Racing Cobra R brake/axle kit and followed the installation instructions provided. No mention is made of a bearing seal having to be supplied seperately so I assume that the bearings supplied with the kit are sealed.
Has anyone had a similar problem or any idea what my problem could be?
Rob
Old 03-22-2007, 08:53 PM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
mustang II brake hubs take a grease seal and wont last very long with out one.
the older i get the faster i was.
Old 03-23-2007, 06:04 AM
Cobra Make, Engine: FFR 5013 - Warmed up & enlarged 302, carb- Painted RED
The SN95 Hubs have sealed bearings, but as delivered have a large amount of anti-sieze on the surface where the wheel attaches (around the wheel studs). If you didn't clean most of that off before mounting the wheels, it ooozes out & is then flung onto the inside of the wheel as you drive.
It's not the size of the dog in the fight, it's the size of the fight in the dog!
Old 03-23-2007, 02:42 PM
rforrester's Avatar
Thanks. I don't think it is the anti sieze issue as the grease is oozing from between the stub axle and the hub (inner bearing). Could I have over-greased on assembly perhaps?
Rob
