November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 05-09-2007, 08:42 PM
Cobra Make, Engine: E-M 351C 428hp
Default Tranny/rear end change
After 2300 miles in 10 days I am thinking about changing transmissions or rear end gears for a little less rpm on highways, what are you guys running?
Old 05-09-2007, 10:36 PM
Burnd's Avatar
Cobra Make, Engine: West Coast Cobra, 427SO 2x4's, 630HP/600TQ
Default 3:73's ...........but to low for my needs.
I am looking to go to 3:50's and 2" taller tires will make up the difference. You can change the tire heigth and make up the difference in the trans, if you want too. It's quick on the hole shot but the low rear has me red lining before the traps. If you got a 3:50 ring and pinion for a 9" rear I'll swap ya.
Bernie
"Shut up and take the pain".
Old 05-11-2007, 12:06 AM
John-Tucson's Avatar
Go with the 3:27 , it's the one used in cars with an automatic transmission. It sounds like you are going to be a driver of your Cobra and that gearing will be perfect. It is an all around gear that you can drive long distances with better gas mileage and less engine noise. The 3:55's are ok also but add a few RPM's. John
John
Old 05-23-2007, 01:11 PM
BPWilliams's Avatar
Cobra Make, Engine: none
I have 350 in the rear and the tremic road race trans with the .80 fifth. Geared for 180mph at red line (160mph was scarry enough). With the big block and the big torque it works just fine. However on long cruises it would be nice to have a lower gear for the freeway and oh ya, GAS MILEAGE!
If you drive go to the 3:27 it will work fine with the light weight of the car.
Brian
There is No Replacement for Displacement.
U.S.A. All the Way!
Old 05-23-2007, 01:52 PM
mikiec's Avatar
Steve,
I have 3:27's in my car. T-5 with a .68 5th. RPM low at cruise. 5th only after 70mph.
Mike
Old 05-23-2007, 01:58 PM
davids's Avatar
Cobra Make, Engine: FFR 302 Mass-Flo mild race engine
Steve, 3:73 17 inch tires..get 19 miles to the gallon on the highway..I'm not changing anything...Thanks for the company out to the FFR show..It was awesome..I can't wait till next year..Dave
Old 05-28-2007, 08:03 AM
Larry N Johnson's Avatar
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
Another vote for 3.27 rear gears.
Keeps the revs down in 5th when cruising long distances.
26.5" diameter tires help, too.
If you have a T-5 or Tremec, the usual 5th OD ratio is 0.68. Some are 0.82, but rarely.
Old 05-28-2007, 08:17 AM
Cobra Make, Engine: SPF 2180, second one, Roush 427, first one SPF 746, 514 Big Block Strocker
My rear end is 3.73 and the 5th gear is .68 on a Tremec, tires 26 in. At 65 t0 70 MPH the engine loafs at 1900 to 2000 RPM and at that RPM the ignition sytem is sill on multiple sparks. Low noise level and good gas milage.
Old 05-28-2007, 08:35 AM
Tony Aprile's Avatar
Cobra Make, Engine: SPF #1358 Silver/Black stripes 466 2X4
3.27 gears
I have a 28'' tall 275/60, TKO600 w/.82 5th gear and 3.27's....this combo is so much better then my original 3.73 gears.
Myself and COBISH have different combinations but similar results in 5th gear, the big difference is I don't have a 1200 drop in RPM's as I shift from 4th to 5th with the .82's, mine is closer to 400 RPM's
Tony
Old 05-28-2007, 02:06 PM
Tony,
Nice setup!!
LNJ
Old 05-29-2007, 02:29 PM
Cobra Make, Engine: FFR MK-I, 302, 780 Pro-Systems custom double pumper, 425HP
I have 3.27 and works great, especially on the long drives 700-800 miles.
Mesa Mike
