Old 06-07-2007, 09:17 PM
snakebitekit's Avatar
Cobra Make, Engine: ERA FIA #2119
Default Webers
I would really like to discuss webers with someone from Az.that is using or has used. I have a ERA FIA on order and am debating on the webers.
I have heard so much negative and some positive (as far as new ways to tune, better fitting) I would just like to discuss with someone who has been there and done or still doing it.
Knowing I will be driving this to Strawberry and above, plus Prescott, etc., and even the heat factor in the valley. I would like to know how well or not they operate. Are they worth it?
Whole bunch of questions that I am sure you have answered time and time again. Additionally, if anyone with webers in a FIA would take me for a ride to feel and hear for myself would be greatly appreciated. This would probably generate more questions.
Dennis
Old 06-08-2007, 03:45 AM
Default Talk to Corky
Dennis Corky has an ERA FIA with webers. Went to the show last Sat. car ran great. no smoke, no problem. Compare motors, his setup should get you in the ball park for drivability. Rick L Sorry I am going with TWM's and FI for my car
Old 06-08-2007, 06:06 AM
dlampe's Avatar
I would be happy to talk to you about webers on an FIA. I am no where near Arizona but I have been there. Just pm me with your number. You can check my gallery to see my setup.
High Maintenance Racing Team
Run & Gun 2003 - 2013
Old 06-08-2007, 07:09 AM
Mulv's Avatar
Cobra Make, Engine: Cobra-less for now..
I passed reading comprehension...
The reason he asked for Arizona experience is that we have an annual temerature swing of 80 degrees and it is never less than 25 F. We have an elevation change of 6000 + feet on our interstate , which only those in Cal can match...
Talk to Joe at Anthem Motors, I think he had them on his Daytona... I may be wrong as the fuel injection setup is similar in look..
Steve
It's under a big W, a big W see?
Old 06-08-2007, 09:15 AM
ENTDOC's Avatar
I think Webers for a small block should be easy, and you should not be intimidated,it is simply not that big of a deal to get them running well once you understand the principle. There is no doubt that a Holley is easier and cheaper but webers are the way to go if you can afford it. Plenty of info here on small block set ups.
Old 06-10-2007, 01:41 PM
Send a message via AIM to phoenix
Default 48IDA's on ERAGT
Hello Dennis.. I am running 48IDA's on my ERA-GT with a 351W. Give me a call if you would like to discuss pro's/con's or if you would like to check out first hand. We are located in NW Peoria 602-317-4713 Thx Jerry
Old 06-12-2007, 09:21 PM
Jerry, thanks for the offer. I will call you. First hand knowledge is what I am looking for. thanks for the response.
Overall how do you like the webers?
Dennis
Old 06-13-2007, 10:36 AM
Default Webers
Hello Dennis,
Look forward to your call.. I love the Webers but they are not without their little quirks. Jerry
Old 06-13-2007, 01:58 PM
Snakebitekit
The above are my 48 IDA’s this may help. The Key is balance of air flow, and fuel is the last thing you worry about. The first thing is get the engine running. If it does run but not smooth that’s OK. To help keep the engine from running to rich or to lean adjust all your fuel metering screws to 1 turn out this is just to get the engine running we will revisit the fuel at the end.
Tuning the carbs takes about 20 min. So maybe some extra fans will help the rad. with air flow.
You will need an Air Flow Meter and a Temp Sensor Gun.
The layout of the carbs is when I say R.R.(Right Rear) it is from the cockpit view point.
Now disconnect the left bank of carbs from the Right bank, should be a turn buckle bar between them.
Start the engine, should still run unless the bar between them was holding one bank of the carbs open then you must turn the idle screw until the engine will run without help from you.
The Sequence for tuning is as follows R.F. and R.R. must = each other. The reading between the two carbs must match and does not matter what it is on the meter as long as both are the same, this is done by adjusting the screw on the linkage between the two carbs , then adjust L.R. = L.F. Once this is done the engine may be racing or could be stumbling you may want to adjust the idle speed a little, try to get it around 1100 RPM’s
Turn engine off reconnect the Left side carbs to the Right side carbs.
Start engine and adjust using the connecting bar and using the flow meter and adjust the Left and the Right bank of carbs, again the reading just has to be the same. By now you should start to understand what is going on here.
If all the adjustments have held the flow thru all the carbs at this time should be about the same.
Turn off the engine
Now the fuel flow. Because you can’t monitor each output of each cylinder we will use two techniques that will give you the best chance of carbs that will perform well.
Just a quick review, Rich is too much fuel and will run Cold at the exhaust. Lean is not enough fuel and will run HOT at the exhaust.
Each carb has two fuel flow meters, one for each cylinder. The book on this is turning the screw in all the way and back out ¾ of turn this is just a baseline. I know I had you adjust them 1 full turn this was to make sure we did not run too lean.
Once you have done this start the engine and adjust the idle to about 950-1000 rpm’s. At this point using the Temp sensor gun, check the output of each cyl.. Check just past the flange about ½ inch away, do not check it on a curve or bend of the pipe that will read hotter and will give you a bigger delta between the outputs of each cyl. The reading will tell you if the cyl are running the same fuel flow. But we want to know if it rich or lean. The book will tell you to turn the screw in on each cyl until the engine stumbles and back out until it is smooth. You may have to repeat this a few time as the engine starts to run on all cyl’s so lets do that and now check the temps again.
The temps can run from 350 deg (to rich) to 800+ deg (to lean) the number will or should be between 600-700 deg each engine will be a little different.
The exhaust temps when the engine is running will or should be within about +/- 10 deg of each other. This will tell you that all the cyl are running close to each other.
When done take it out for a test drive it should be fine if timing is set right, if you do have a flat spot on hard throttle could be timing or the run jets need to be changed this gets a little more involved. But most of the time it is timing and or the advance springs are wrong.
48 IDA’s will not get you great gas mileage but depending on horsepower can be between 6-14 mpg . My 351w above put out 500HP and got around 7mpg
Good Luck
Joe
Old 06-13-2007, 07:02 PM
Cobrajo lots of info thanks.
dm
Old 06-13-2007, 08:02 PM
Full Throttle Al's Avatar
Cobra Make, Engine: CSX4083, NOS 427 SOHC, serial number 589. Dyno'd in 1967 at 629HP with single 4v 560 Holley. Now with 4 Webers.
Nice new small block complete Weber setup for sale, new, polished, chromed:
Alan J Sorkey
Shreveport, LA
asorkey@hotmail.com
