Old 02-06-2008, 11:45 AM
mikiec's Avatar
Default Jeff.................
I'll bring the tranny jack by tonight. I'll call you when I'm close to your place.
Old 02-07-2008, 01:51 PM
mikiec's Avatar
Jeff,
I have some free time here.... What D-link do you have?
Old 02-08-2008, 03:04 PM
vettestr's Avatar
Mike,
Dlink is a DI 614+ via a motorola SB5120 surfboard modem. I do not often check the board through the day so call if any ?'s or need an answer quickly. THANKS Jeff c
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 02-08-2008, 03:22 PM
mikiec's Avatar
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
Old 02-09-2008, 12:00 PM
vettestr's Avatar
%R^&*)(OP}} .......... still does not work !!!!!!!!!!!!!!!!!!
Mike I had gone through the reset you described a week or so ago but did not allow specific times between steps but did wait as described in owners manual. This time or this reset I doubled time for steps and still no help.
Each time I was getting the sense reset took because it wiped out passwords and things that worked before reset. FUBAR !
Jeff Classic
Old 02-09-2008, 01:32 PM
mikiec's Avatar
Are you going to make 83rd tonight? If so, bring me the router and I'll try it at my house.
