Old 07-30-2008, 06:46 PM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Default SB engine identification
Hey all you SB gurus,
I am going over to help identify a 289 or maybe a 302 for a friend. The wife has no clue what her late husband has tucked under a tarp. It could be a circa 70's up to maybe late 80's engine I would guess, has finned Cobra V covers for what the little that means.
I need a push in the right direction, where are the numbers and date codes on the block and a head. This engine is assembled but I can pull the valve covers or what ever is needed. THANKS for your help. Jeff C
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 07-30-2008, 07:03 PM
Danr55's Avatar
Jeff, Give me a call tomorrow night.. I'll give you all the information you need. I have reference material that provides all of that information. I should be home after about 3:00 tomorrow.
Dan in Arizona
CCX3209
Old 07-30-2008, 07:27 PM
vettestr's Avatar
Thanks Dan,
Please PM or send the best # to reach you at to my email at jeffc@cobrasnvettes.com
THANKS
Jeff Classic
Old 07-31-2008, 01:37 PM
Danr55's Avatar
Jeff. Check your email.. You've got some information. Sorry that I can't translate it into Chebbyspeak..
Dan in Arizona
CCX3209
Old 07-31-2008, 02:56 PM
vettestr's Avatar
THANK YOU
I will get somebody to read it too me.
These will be a big help.
Jeff C
Jeff Classic
Old 08-04-2008, 12:18 PM
vettestr's Avatar
Default 1966 289 with a 4" bore
I am editing to add the E to cast number. The E makes this a correct date and code for a COBRA
It was a 289. The block is # C5AE-6015-E dated April 19 of 66 with the heads coded C6AE and dated Feb 21 of 67.
The heads have had all seats replaced and looks like new valves and springs too. I am guessing guides were replaced but adjustable rockers have been installed and guide plates have a Ford part # visible. No porting or gasket matching has been done on the stock castings.
The block is a 4" bore as measured with dial calipers only. The bore is a fresh hone with no rust or any corrosion visible from storage. The pistons are flat top with eyebrow valve relief's. Deck does not appear to have been cut.
I will list this in the for sale area with photos later tonight
Jeff Classic
Last edited by vettestr; 08-07-2008 at 09:26 AM.. Reason: added the E to casting number that's on the block
