02-16-2009, 08:20 AM
tremec transmissions
Has anyone in the Phoenix area had any success with work on a Tremec TKO 600? I would like to have some checks made on mine.
Dan in Arizona
CCX3209
02-16-2009, 08:27 AM
Cobra Make, Engine: Car builder/restorer FFR
Dan, I really don't know anyone qualified to work on one. What checks do you need? Any more than a standard fluid change does get really expensive.
02-16-2009, 01:58 PM
THanks Gordon. I need the input shaft changed. When I bought the tranny from Anthem, it had the wrong shaft in it and they didn't change it. They installed a 1" spacer plate instead. AMP.. "All Mustang Performance" works on Tremecs. They said about 1 hour and $200 to R&R the shaft.
Dan in Arizona
CCX3209
02-17-2009, 06:01 PM
az
Cobra Make, Engine: Kirkham 289FIA, roller
Dan, I swapped mine out successfully. There was a post in the transmission section, but I failed to find it to post here. I believe I printed it out and could fax it to you if you'd like. If you'd like, pm me and I'll be happy to help in any way.
Mark
02-17-2009, 06:46 PM
THanks Mark. If I get stuck, I'll call you. Bet on it! RIght now it looks like the guys at AMP have it pretty well handled.
Dan in Arizona
CCX3209
02-17-2009, 07:01 PM
AZ.
Dan,
Your in good hands. Don't give that plate away ! PM me when you get a chance with your cell phone number. The # I have is not going through??? Jeff C
02-17-2009, 07:32 PM
az
Not that it matters, but I did another search and managed to locate that thread: DIY Short Input Shaft
I bought some parts from AMP and they had just what I needed and treated me well.
Good luck and give me a shout if I can help.
Mark
02-18-2009, 08:13 PM
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Originally Posted by vettestr
... PM me when you get a chance with your cell phone number. The # I have is not going through??? Jeff C
Jeff, there is a reason for that. After Dan saw what the Feds did with the phone taps on Blagojevich, he now changes his number every other day!
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
02-18-2009, 08:33 PM
Ill
I want you guys in Arizona to know that it was rumored the CIA tracked Ralphie by satelite. Was OBama with Warren and Judy???
