November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 10-14-2009, 07:32 PM
Exclamation seat belt warning systems
some help here please, what seat belt warning systems are currently being fitted ?
I need to sort out whats best to use for rego
rog246
Old 10-14-2009, 07:41 PM
boxhead's Avatar
This is what I have built and fitted.
http://www.jaycar.com.au/productView...r&form=KEYWORD
Cruising in 5th
Old 10-14-2009, 07:49 PM
LoBelly's Avatar
snakebite have one too...
http://www.snakebite.com.au/seatbelt...mer-p-178.html
LB
Old 10-14-2009, 09:08 PM
WKB's Avatar
WKB WKB is offline
Cobra Make, Engine: Harrison Cobra, SC540 Roadster
I got mine from Warwick, but DRB have them as well.
Warren
Wodnas's Avatar
Cobra Make, Engine: Harrison #95, 302 HO
Rog, I used the one from Snakebite because I already had it.
You could also program your Isis to turn this light on for a set period of time each time you turn your ignition on. You would not need to buy anything else then.
Cheers Bob
Harrison No 95
Mt Tamborine Qld
Old 10-14-2009, 10:14 PM
Hey thanks fellas.
Bob thanks for that. was kinds hoping that option would be available to me. I'm hoping ISIS will save me some $'s by being able to do all those sorts of things
Old 10-14-2009, 10:23 PM
gjkrv8's Avatar
Originally Posted by Rog246 View Post
Hey thanks fellas.
You can also probably get your ISIS to do the ALT warning light sequence as well. i.e, it comes on as a test whilst IGN is on but then goes off until ALT fails - I had to use a diode for this, but your ISIS would be smart enough to handle this as well I'd say (probably already programmed for this already).
Rgds
gregg
Old 10-15-2009, 09:59 PM
Thanks Gregg, any additional info is always helpful
