Old 03-14-2010, 04:09 AM
07cob's Avatar
Default Boot Trim
All
More than two years after rego, I have finally managed to stop driving my car for long enough to trim the boot. Just a couple of things to finish it off. Here is a photo to prove it.
Geof
Old 03-14-2010, 04:11 AM
boxhead's Avatar
Looks good one F Geof.
Cruising in 5th
Old 03-14-2010, 05:21 AM
Merv and Sharon's Avatar
"Stairway to Heaven"?
Well done Geof!
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 03-14-2010, 12:13 PM
schipps's Avatar
Default Boot
Geof,
That looks great, nice job
regards
Schipps
Old 03-14-2010, 02:53 PM
SunDude's Avatar
Cool! Now, you're gonna hafta get some matching luggage.
Old 03-14-2010, 02:59 PM
Wazza's Avatar
Nice work young Geof....Looks great.
Warren.
Old 03-14-2010, 06:04 PM
Different and original idea! Nice.
SpookyPT
Old 03-14-2010, 06:28 PM
FWB's Avatar
FWB FWB is offline
looks better than my living room.......what are the 4 doo-dads on the floor?
Old 03-14-2010, 07:43 PM
sambo's Avatar
Looks great Geof. Gas struts are nice too. I'm guessing those 4 "doo-dads" are tie-down points for a cargo net?
Old 03-14-2010, 09:28 PM
07cob's Avatar
Thanks Gents
Yes, the doo-dads are flush mount tie down points. I got them from the chandlery where I picked up the marine carpet last weekend. I have been looking for the right colour carpet for a while and just happened on this while I was looking for something altogether different. I saw the tie downs and had to have them.
Merv, I was actually hoping to avoid the 'stairway' look and could have, but floor space would have been comprimised by around 25% so I went with the steps.
SunDude, I don't know about matching luggage, but I will now have to redo the interior to match. I just don't know if the interior can carry two stripes all the way through. It might be a bit of a stretch. We'll see.....
Geof
Old 03-16-2010, 05:24 PM
byroncobra's Avatar
Hey Geof
Nice stripes!!
How'd you fix the blocks for the struts to the body........I'm sick of the broomstick falling down
Greg
Old 03-16-2010, 06:47 PM
Wazza's Avatar
Gotta love the struts...
Seeing "One F" Geof's car take shape had convinced me to have struts as well.
The previous Cobra's "Stick" in the front and in the back always left me a bit cold....
and after the bloody stick had let the bonnet drop a couple of times...always knocking paint as it went...it had me making sure there was a better way.
Thanks Geof...
Warren
Old 03-16-2010, 08:26 PM
byroncobra's Avatar
Warren
I've been looking into gas struts and according to the manufacturers of these things, Stabilus, i should not use anything over 150nm pushing force or the body may distort when bonnet's closed. I guess this can be reduced by enlarging the fixing area for the hinges.
Apparently your average auto bonnet strut is about 350nm, this is needed to hold the heavier steel unit up
Where did you source yours and any thoughts on the above?
Greg
Old 03-16-2010, 10:44 PM
Yes, some guys had the struts and had to remove them because of deformation.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 03-16-2010, 11:17 PM
Wazza's Avatar
I had these supplied, and took advice from "Struts R Us" here at Nerang on the Gold Coast.
Yes..they are easily set up incorrectly.
If you have a look at mine you will see that as the boot closes..it actually helps pull the boot shut.
I have seen them mounted so that they are always trying to push the boot open, and that's when they end up deforming the lid.
When mounted correctly they basically have to be set up to help open the boot / bonnet, and when the boot / bonnet is closed there should be hardly any "push" still happening from the strut.
Basically...If they are roughly at 90 degrees to the lid/bonnet when open, and then at a very "flat" angle when it's closed they should work o.k.
If the strut is still "pushing" when the lid/bonnet is in a closed position, to me that would be when they push things out of shape?
We'll soon see if they cause any dramas...but seem to me that they'll be fine...I could be wrong.....gotta "suck it and see".
Warren.
Old 03-17-2010, 12:34 AM
byroncobra's Avatar
Thanks for that Warren,
I'll give the guys at Nerang a call
Greg
Old 03-18-2010, 03:46 AM
07cob's Avatar
Default Struts
Greg
The brackets inside the boot are just 50mm angle brackets tek-screwed to the same cross member the boot hinges are swung from. On the boot (and the bonnet), I made up some Al angle brackets and glassed them to the boot/bonnet. They got painted and look like part of the body.
Warren is absolutely right about the fitment. They need to be fitted so they are effectively *over-centre* when the boot is closed so that the strut is keeping the boot shut. My struts are quite small and not too powerful. They are from the windows on a 4WD fibreglass canopy.
Warren, it was actually the bonnet stay on the bumble bee that inspired my struts in the first place. I recall the bonnet up at a breakfast meet and a string attached to stop it opening up too far and thought that there must be a better way. Struts seemed the obvious choice.
Geof
Old 03-18-2010, 05:05 AM
Wazza's Avatar
You're right...although that yellow string was state of the art...I've decided that I'll go high tech on the new one.
Warren
Old 03-18-2010, 05:31 AM
What would 'old Shel think?
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 03-18-2010, 03:15 PM
byroncobra's Avatar
Geof & Warren
Unfortunately I'm painted so glassing on is a prob, I'll come up with something, thanks for the tips though.
Spoke to the guy at Struts r us, very helpful
Greg
