Old 03-27-2010, 04:14 PM
Outwest34au's Avatar
Default Engineer help.
When I first bought my rolling kit I called an engineer in NSW for advice on how to proceed. He seemed to take great delight in shouting me down and discouraging me from building it at all. Since then I have progressed with ADR's and other CC members experiences as guidelines to a point where I am very close to startup stage.
I am seeking advice from you guys as to who I might use as an engineer. I would like to be able to work with them using emails and pics until the time comes for a physical inspection. I have engineering paperwork from other registered cars and know that torsional testing and fibreglass testing figures are available.
I mainly need to run my thoughts on seatbelt mountings and brake setup (will they let me use wilwood dbl cylinder with balance?) past an engineer before proceeding.
The kit is an Evans with L76 and 6 speed, Jag f/r suspension.
Any help here or through PM's is greatly appreciated.
Ya get that on big jobs.
Old 03-31-2010, 03:49 AM
OZCOBRA's Avatar
Question Sorted???
Still looking for assistance or have the guys helped out through the PM's...OZ
Old 03-31-2010, 04:49 AM
acecob's Avatar
Default Engineer
Call this guy
His name is John from Consulmotive Tel: 91530011
He's in the Peakhurst area, he has an A rating at the RTA
Tell him Peter Georgiou recommended you
He should be able to help
Just looked at your location in your details, were you after someone in NSW
Old 03-31-2010, 04:57 AM
Zedn's Avatar
Acecob,
Do you know if Consulmotive can do the torsion and beaming test for chassis?
cheers
Old 03-31-2010, 05:04 AM
acecob's Avatar
He probably can, but I'm not sure
Just give him a call he'll be able to tell you who can if he doesn't.
Old 03-31-2010, 05:15 AM
Zedn's Avatar
I have spoken to Kevin at Wyong. He has the set up to do it and was helpful on the phone, but Peakhurst is closer.
cheers.
Old 04-01-2010, 05:18 AM
LT65's Avatar
Cobra Make, Engine: Harrison #77
PM sent.
Lionel
Old 04-01-2010, 02:07 PM
Thanks for the advice guys. Not sure how much closer I am but Thanks.
