Old 12-19-2010, 04:34 PM
Cobra Make, Engine: Classic Revival 3506
Default Big brakes for Jag front end XJ6
Hi guys found this ,it maybe of interest to those using XJ6 front ends
http://www.yourhotcar.com/prod/Kspor..._Front/808044/
Old 12-19-2010, 04:43 PM
boxhead's Avatar
Default Sunshine NSW
They look pretty good Paul.
Save a tone of weight ditching the cast iron calipers
Cruising in 5th
Old 12-20-2010, 01:18 PM
Cobra Make, Engine: Venom, BF XR8 260kw, 6 speed auto
Just a word of caution before spending the big bikkies, get approval from the engineer, as mine will only sign off non OEM brakes on a case by case basis. Some of them won't sign off non OEM particularly if they dont have dust seals, which is an ADR requirement but not a US design requirement.
Nathan
Old 12-20-2010, 03:41 PM
Cobra Make, Engine: AC Adelaide Cobra - 351w & 4-Spd Toploader C/R - "Construction Underway!"
What THE! Am I reading the price right? $1599.99 USD. There is a lot of more "needy bling" to buy for that price.
Old 12-20-2010, 11:48 PM
Philm's Avatar
I think these brakes are big but I would check if they are better.
Much better brands out there for that price.
Phil
Old 12-21-2010, 05:14 AM
Zedn's Avatar
Nathan
See if you can find it in the ADR...
Old 12-21-2010, 01:30 PM
Outwest34au's Avatar
"5.1.1.2. In particular, the braking equipment shall be so designed, constructed and fitted as
to be able to resist the corroding and ageing phenomena to which it is exposed."
I guess like a lot of the rules it is open to interpretation.
Ya get that on big jobs.
Old 12-21-2010, 01:37 PM
Zedn's Avatar
I'll say it is. The material the piston is made from can be said to do this.
Much easier just to use standard Jag that are easily big enough and spend the money else where.
Old 12-23-2010, 05:39 AM
10 Kg each caliper...unsprung weight. Not too desirable. I've been looking for lighter brakes for ages and last night I saw Brembos with a blank mounting flange. ie drill your own.
I haven't looked further yet but I will later. need to know what size rims they will fit into.
Old 12-23-2010, 03:31 PM
Default big brakes
Sounds interesting Rob , keep me posted .
Thanks Merry Xmas
Old 12-23-2010, 05:08 PM
Yeah, keep me posted with your findings Rob.
I just hate those bluddy heavy jag calipers . Been looking for an alloy substitute for a while.
Old 12-24-2010, 03:12 AM
Ok don't hold your breath. I've been looking for ages and my new job has slowed all things Cobra down to a crawl. I will let you all know when I get the goods. It looks like this is a big issue ! Ksport seems to be at every auto show flogging all sorts of drifting stuff.
Old 12-25-2010, 06:56 AM
Cobra Make, Engine: Robnell Blown LS1
Try these guys, www.vicspiteri.com.au . They have vented rear discs for the jag set up and they showed me a nice set of alloy front calipers that they manufacture which look very nice indeed....
