Old 03-19-2011, 05:09 AM
Zedn's Avatar
Default engine mount experience
Hi all,
I am up to fabricating engine mounts for my car and i cant decide what to use.
Can some of you give me feed back on what you used for engine mounts and how they have performed. eg vibration, longevity etc.
Currently deciding between buying some nolathane bushes and fabricating some brackets out of tube and 5mm sheet with a bolt in double shear. kind of like these.
http://cgi.ebay.com.au/TUFF-MOUNTS-G...item3cb463d758
Or going with the square rubber typed engine mounts and fabricating some brackets to work with them. Using these.
http://cgi.ebay.com.au/Holden-V8-eng...item519850f468
Any pics of what people have made up would be appreciated. Im running an LS3.
Cheers.
Old 03-19-2011, 11:46 AM
G'Day Zedn,
I've got the double shear type with nolathane bushes and have no vibration problems or noise transfer. Alignment for the 'pins' is a challenge but I simply loosen the plate from the engine and the holes can be aligned easily
Old 03-19-2011, 02:32 PM
Cobra Make, Engine: RCM
Default engine mounts
i fabrica ted steel mounts on the chassis then used the original factory mounts no vibration at all have some photos
Old 03-19-2011, 04:29 PM
Whiteline have an after market LS mount"
http://www.clubcobra.com/photopost/d...nts_Small_.JPG
Old 03-19-2011, 05:13 PM
Zedn's Avatar
I havnt seen those before. Quick search says they are around $300. Thats pretty similar to what i am going to make.
Bushes from supercheap auto are about $30, i already have heaps of 5mm steel and i just need a couple of bolts and a small bit of pipe. Should be under $50 in materials.
I was just a bit concerned because of the way nolothane bushes tear and crumble. Worried about how long they will last.
Old 03-19-2011, 05:38 PM
Originally Posted by Zedn View Post
I Bushes from supercheap auto are about $30, i already have heaps of 5mm steel and i just need a couple of bolts and a small bit of pipe. Should be under $50 in materials.
Frankly, I would suggest you make them myself. Indeed, this is exactly what I did because I wanted a mount with a different vertical height above the side rails. ie. get a better tail shaft alignment to the diff pinion.
The whiteline units are made to replace the Holden round donut type unit which has shown some shearing problems. ie. The standard holden mounts are great for NVH issues but have little resistance to lateral movements.
If you search on LS1.com.au I think you'll find these (Whiteline) are very reliable. Providing you protect them with the GM heat shields.
Old 03-20-2011, 03:04 AM
boxhead's Avatar
I used factory Holden mounts, I figured GM had invested a fair chunk of change, so they should be ok
Cruising in 5th
Old 03-20-2011, 03:38 AM
Totally agree but the RMC chassis rails are very close together so the GM alum engine mount brackets and the rubber engine mount are not suitable without major surgery.
Look in Baz's gallery and one can see the surgery that Neil Streeting did to that RMC chassis to use the standard GM bits. Chassis mods which could well cause an engineer to insist on another beam test.
Not all Cobras are manufactured to accept GM engines.
Old 03-20-2011, 03:39 AM
renovationinnov's Avatar
i agree boxhead , i just got new one from repco but used a old set for the set out
Old 03-20-2011, 03:56 AM
boxhead's Avatar
The CR requires the American mounting ears, I had a left and right Aussie one.
Cost me $100 to get the R/H mount modified to suit.
This is the factory L/H mount, you see it did not line up, after investigating, I found this mount was correct, but R/H was wrong.
And modified R/H mount.
Which is the same now as the American R/H mount. They are closer to the block, If needed, when I get home I am happy to measure my engine mount spacing from one side to the other.
Cruising in 5th
Old 03-20-2011, 04:06 AM
Yep... been there, done that. Got the GM alum thingys and the GM mounts.
To give you some idea, The bolt protruding from the top and the bottom of the GM rubber engine mount hits the very center of the chassis side rail, That chassis rail is a 4" section. Whereas in the pic posted by Boxhead that bolt is inside the chassis rail.
Further the center of the diff pinion is in a line 1" above the bottom plane of that chassis rail and is horizontal ... that is 0 degrees.
Old 03-20-2011, 04:17 AM
So as in the pics in Baz's gallery the base of the rubber mount shown in Boxheads pictures as being level with the top of the chassis rail has to be level with the bottom surface of the RMC chassis rail.
Real bugga really
Old 03-20-2011, 04:23 AM
Here is the pic from Baz's gallery. As you can see Neil cut the inner rail and boxed to the side rail and a flat plate at the base on which the rubber mount sits.
That is major surgery to me. Much better to leave the inner chassis rail. Toss the alum GM mounts and make new compact steel ones and use a urethane mount not unlike those shown earlier.
Old 03-20-2011, 04:58 AM
And here is a cut and shortened GM mount in my chassis in an attempt to get the mount bolts inside the inner side rail. Achieved the narrowing but was still too high in the chassis.
Problem was ... tailshaft to diff pinion alignment ....was still 40mm too high above the side rail.
That lil pink vehicle in background belongs to #1 grand daughter. )
Old 03-20-2011, 02:07 PM
Outwest34au's Avatar
For my L76 I used Ford clevo mounts. I was advised to add the bit of angle iron to prevent engine roll, sort of a mechanical stop. The chassis had hollow bar already welded on to accept some other sort of mount, I just had to extend them 1/2 inch or so to fit snug in the clevo mount.
I will replace the 50mm flat bar bolted to the engine with a plate that uses all 5 holes on the block.
I reckoned that I would be able to get clevo mounts at any corner store if they needed replacement by the roadside and that upgraded mounts would be readily available also.
As far as experience with them goes,,,,, I can only say the engine never fell out on my 200 metre test drive.
Ya get that on big jobs.
