questions
- » Blogs
- » Image Gallery
million posts!
November 2025
| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
08-09-2011, 10:18 PM
Vic
HSS tap die set suggestions
Guys
Want to chase initially a metric high speed steel tap die set for when I get back to the cobra. Looking at say 3-12mm sizing only.
What brands can anyone recommend? My memories only take me back to P&N!
Noted a Hare and Forbes ad for a Toolmaster brand set in HSS but I assume even as HSS there are good and bad tools. What is the Toolmaster brand like as the H&F price was good I thought.
I had been looking at Snap-On gear but realised these aren't HSS grade.
Any advice would be appreciated so I don't go buying something crap.
Steve
slowy
Advertising
08-09-2011, 11:00 PM
CA
McMaster.com will provide you anything from HHS to carbide with all kinds of surface coatings for rolled or cut threads.
Ed
08-09-2011, 11:01 PM
CA
Deleted duplicate post
08-09-2011, 11:09 PM
QLD
Originally Posted by stephen low
Guys
Steve
Steve I've had a set of Kingchrome for 30yrs and have never had a problem. Just remember what ever set you use get some cutting paste to go with it. It will not only keep the taps/dies sharp but you will get a better thread quality as well.
Rog
Rog 246
Harrison #100
08-10-2011, 01:31 AM
Vic
Cobra Make, Engine: Classic Revival CR3514, LS3, Dual Quads, Holley Dominator EFI, TR6060, VE 3.7 LSD, AP Racing Brakes, 17x8 & 10 Custom Dragway Billet Wheels.
Steve, i've got a cheapy "Total Tools" set, about 34 Bucks, with a range of intermediate and blind hole taps and dies from 5 to 12mm, as rog says, get some trefolex paste, makes the tools cut clean and easy, the smallest size tub you can get will last a life time. (about 250grams) cost was about 9 bucks,
cheers
08-10-2011, 01:52 AM
vic
Go to a good tool shop and buy a brand name.
P&N are great as are Sutton. Chinese crap is precisely that, CRAP!
Powered by Cu
08-10-2011, 02:30 AM
VIC
There are some good quality Taiwanese sets around, I had 2 big metric and imperial sets that ran from 6mm up to 25 mm and 1/4 up to 1" in both fine and course pitch. They lasted me near 20 years. I bought another Taiwanese set the other day from Radum in Tullamarine. Cost about about $260 and has a good range of sizes in there including some taper taps. This one also has a lead tap and intermediate of each size which is handy.
Mike Murphy
Melbourne Australia
08-10-2011, 03:43 AM
Vic
Ed
McMaster wont ship to Australia
Ben in AU
08-10-2011, 04:51 AM
Qld
Cobra Make, Engine: DRB, FORD 302W,T5
Suttons have what you need --they have boxed sets that include tapping drill , tap and clearence drill --imperial or metric.
Rocol tapping compound is best alround
Cast iron -dry
Aluminium -kero or Rocol
Stainless steel - Gee (unsalted butter) or Rocol
Steels - soluble oil or Rocol
http://www.sutton.com.au/Assets/1420...edtapdrill.pdf
rocol.com.au - RTD Liquid
08-10-2011, 05:35 AM
QLD
Originally Posted by Mrs flatchat
Aluminium -kero or Rocol or Soap!
Stainless steel - Gee (unsalted butter) or Rocol or soap !
Rog
Rog 246
Harrison #100
08-10-2011, 07:24 AM
PA
i would save the money on the dies........just buy them as needed. you will use them very rarely. the taps, are a different story. be selective don't just go and buy a set. buy the sizes you need.
google your local industrial supply there in AU.......you will find many names of taps. don't get hand taps........get spiral flute gun taps, plug,.. they are stronger. the hand taps are 3 and 4 flute and the webbing is thin they snap off easily. the gun taps have one flute and will take more punishment.
if the supplier has a HSS cobalt get them they will be the strongest. a TIN coat will help with stainless tapping. as far as cutting oil, a dark sulfuric oil is the best.....yeah you can get buy with the soap and the kero and other home brews but after two holes the tools will be dull. get the cutting oil!!!!
regards, fred
Fred B
08-10-2011, 08:21 AM
VIC
I must admit that over the years the common sizes that I use heve been replaced wit good quality taps from Goliath threading. I usually buy the set of 3 of those sizes ie lead, intermediate and bottom.
I've also bougt a bunch of one off sizes from them like left hand taps, taper taps and Whitworth.
Mike Murphy
Melbourne Australia
08-10-2011, 06:31 PM
Vic
named suppliers
Thanks folks for the extra details.
Gav had forgotten about Suttons cheers.
Mike I wouldn't know a good Taiwanese set from a ****e one to be honest so I'd rather get a brand name. Even the reference to the Hare & Forbes supplied brand of Toolmaster I have seen that brand name before but have no idea if it is good, bad or indifferent.
And thanks for the reminder on cutting oils I'll get a tube too.
Steve
slowy
08-10-2011, 07:34 PM
GA
I don't understand the physics. However a three fluted tap always seems to cut easier than a four or two flute tap. Four flute break the easiest, even the good ones.
Also spiral fluted will cut a stringer out. Meaning you will not have small chips, but a long string of a chip that spirals out.
08-11-2011, 04:24 AM
Qld
Production taps:-
Gun taps are the toughest, primarily designed for driving the swarf to the bottom or thru the hole --idealy thru hole.
Spiral taps idealy for blind holes --screws the swarf out of the hole
Roll taps idealy for sheet metal --forms a thread rather than cutting one.
Hand taps --a handy desperate last resort
UNC or NPT taps give the most drama with chipping, galling or breakage -- just a PITA
Pipe threads BSP (or NPT if you must) use "gun" taps straight ( the fitting is tapered for a jam fit) Most Ford stuff is NPT.
BSP and NPT look similar , but -- 1/8" - 3/8" is one pitch / " different, 1/2" - 3/4" same pitch, 1" - 2" half pitch / " difference - not to mention incl.thread angle, BS is 55°, UN is 60° along with metric
Metric taps -- for drilling size, just minus the thread pitch from the nominal O.D. eg M10 x 1.5 -- 10 - 1.5 = 8.5
Dave W --"Trefolex" (green death) is laced with asbestos or other carcinogens is it not ?
08-12-2011, 06:03 AM
NSW
TOOL MASTER is chinese or tiawanese they are reasonably ok if you take care when using them. Don't lend them out and be prepared to replace them as they get blunt.
08-13-2011, 05:35 AM
Vic
Flatchat,
Trefolex is green, but i'm not sure about the carcigens thing, the msds says it contains petroleum gel, talc, vegtable oil and tallow, and that it may cause eye irritation if you stick the tap in your eye, but other than that all good.
Dave
08-13-2011, 04:10 PM
NT
I just buy quality tas in the size I need, building my car I found M8x1.25, M6x1.0 & M8x1.5 covered just about everything
Cruising in 5th
