08-27-2011, 05:56 AM
Good work Boxhead, I reckon 1 bar looks heaps better than 2. Make sure you post some pic's of the fans in position.
Regards.
Mando
08-27-2011, 03:11 PM
Super Moderator
Damn nice work...simple and clean.
By the way, with regard to your sig line...please remember that the ark landed on Mt. Ararat, which is in Armenia.
We invented everything...Greeks and Turks steal.
...just sayin.
Jamo
08-27-2011, 03:58 PM
NJ
The original fans are very inefficient even if they DID have a shroud around them when compared to modern fans of the same diameter. Still, they represent "original" and look good but that's about as far as they go. In addition to the original fans, I mounted a SPAL 16" puller fan on the rear of the radiator and that does a good job keeping the motor out of trouble even on the hotter days. I also use a thermostatic sensor in the radiator fins for the fan to come on automatically at 195* and a manual override switch on the dash just in case I want them turned on sooner. OH, I have things wired so all fans come on at the same time. Thus far I have been more than satisfied with the performance. I originally mounted the fans so the center of the fan was approximately halfway up the radiator. The fans appear to be higher because the radiator is tilted backwards so the fans are actually pointing somewhat downward. The motors are to the outside with the fan blades closer to the radiator.
08-27-2011, 04:15 PM
I may be missing something but if the motors only turn in one direction why not simply turn the fan around?
Regards.
Mando
08-27-2011, 04:48 PM
vic
Looking good Dave, very nice.
I think Andy may be off the hook for the 'heaviest cobra' cobra award though
Powered by Cu
08-27-2011, 04:54 PM
NT
 there is at a guess3 - 4 kg in the brackets and fans.
If I was worried about weight, I could drop alot of kg and still be heavier than you.
Cruising in 5th
08-27-2011, 07:55 PM
Cobra Make, Engine: Purchased CSX3225 in 1968 for $4,995. Original 428 car but changed to 427 MR about 20 years ago.
I know some cars came with two fans but my original car came with only one fan in the middle. The car would overheat in heavy traffic. I added a second fan like shown which solved the problem. I now have a large puller fan in back of the radiator which works even better. I had trouble with the fan blades breaking when I was driving the car about 12,000 miles per year. I think I had to replace the fan blades about 4 times in 60,000 miles.
08-28-2011, 05:58 AM
NT
I managed to finish the fit up of the fans this arvo.
As time permits I will pull them off and paint the motors black.
Here you can see how I mounted the frame to the chassis.
And in place.
Cruising in 5th
08-28-2011, 06:02 AM
rms427,
Nice car!!
Regarding the cracked fan blades; All blades on the pair of fans I removed several weeks ago showed small cracks.  I have about 14,000 miles on the car.
08-28-2011, 06:16 AM
Qld
I need to get a pair of blades, wre is the best place to get them?
Australia would be great.
Phil
08-28-2011, 10:53 AM
Super Moderator
Boxhead, my highest praise...mucho muy goodo.
Jamo
08-28-2011, 02:53 PM
Dave, by the look of that radiator, those fans will also be good bug slicers! May also deter local 'roos.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
08-28-2011, 05:17 PM
Stolen Avitar
GA
Boxhead, I don't know if now is a good time to mention this but there was a reason that I went with 2 cross bars holding the top and bottom of the motors. Mine is the first car in post #5 BTW (BDR687). The guy that I originally bought the motor/fan setup from had only a top bar like yours but it was fairly flimsy feeling. When I mocked them up>1" from the radiator it really seemed that If I were to lean on the car (which I do) that the fans might contact the rad core. I don't know what's original and what's not but that's why I added the second bar. Just thought I'd mention it.
Steve
08-28-2011, 05:55 PM
vic
I wouldn't worry about the second bar Dave, with the way you have built it I would think using it for a tow hitch would be ok too!!
Powered by Cu
08-28-2011, 06:56 PM
NT
Hi there Steve, the construction is pretty solid, I grabbed it with both hands and yanked forward and backward, I thought the car was going to fall off the hoist, but the fans did not move.
Cheers Gav, she aint moving alright
Cruising in 5th
08-28-2011, 07:04 PM
NT
Oh man, a mates son just commented when he saw a picture of my Cobra with fans in place "Daddy, why did that man put Towmaters teeth on his cool car"
Cruising in 5th
08-28-2011, 07:26 PM
VIC
I think your car has just got a new name. We'll have to call it Mater from now on.
Mike Murphy
Melbourne Australia
08-28-2011, 07:31 PM
NT
May as well, I too have Maters teeth.
Cruising in 5th
08-28-2011, 08:35 PM
ACT
Phil
Phil, they look like comercial aircond condenser fans to me. They come in many sizes. Try Actrol, Lovelocks or any comercial aircond supplier.
Is this where you got yours Dave?
SLIPRY
08-28-2011, 09:29 PM
NT
I got mine from Baz earlier this year.
Same as what Finishline sell.
Cruising in 5th
