Old 10-20-2011, 02:35 PM
I have an ls3 butterfly if u want one
I mainly use it for testing looks before I send em out
Give me 150 bucks plus your throttle body
my website
www.sideshowsperformancewiring.com.au
Old 10-20-2011, 02:59 PM
my website
Old 10-20-2011, 03:03 PM
Doubledip's Avatar
Send a message via ICQ to Doubledip
Originally Posted by Zedn View Post
I hope i have the correct ECU. I was told it was out of an LS3 with securities removed.
I was told this TB is also off an LS3.
Does this sound correct? Is there a number on the ECU to look for?
Service # 12625455
or
Service # 12633238
not sure what you paid for your throttle body but might be something worth considering getting the one of Jim... just be very careful about heat near the butterfly as they warp real easy.. has seen heaps of shops try and modify them (some successful , others not).. plus be very careful with the solder/ rivet ideas... i wouldnt want to go dropping anything into the intake of my car while running..
www.ultimateconversionwiring.com.au
_
Old 10-20-2011, 05:46 PM
Baz's Avatar
Baz Baz is offline
Doubledip,
Hi Justin,
I sent you a PM yesterday. Did you get it?
Baz
Old 10-20-2011, 05:56 PM
boxhead's Avatar
Zedn, Why not remove the butterfly and measure it?
I am sure if you did a Google search you will find a seller of blade only?
I am thinking it is 90mm?
I have a couple of LS1 throttle bodies kicking around, not sure if you can make this work?
Cruising in 5th
Old 10-20-2011, 07:11 PM
Aussie Mike's Avatar
If its Brass can be easily soldered but Why not just try it out before doing anything?
Mike Murphy
Melbourne Australia
Old 10-20-2011, 11:38 PM
Gav's Avatar
Gav Gav is offline
Worse case, just tap the hole and put a very flat machine screw in it, and file it flush on the other side.
If you are not planning on rebuilding the engine as an all out racer, the tiny bit of turbulence the screw creates will not do FA.
LS1's have a throttle body 15mm smaller than a LS3 and they will still flow 400hp.
Powered by Cu
Old 10-21-2011, 01:01 AM
Personally I would just ask on ls1 forums
For another one or a swap
I would never risk a 6 grand motor because I
fitted a screw or solder to the butterfly
And it went threw the motor
my website
Old 10-21-2011, 01:10 AM
boxhead's Avatar
I would prefer to see it replaced.
Cruising in 5th
Old 10-21-2011, 01:13 AM
Gav's Avatar
Gav Gav is offline
Is it only me or is the butterfly held on with machine screws?
Maybe GM and every other engine manufacturer through out history has made a monumental design blunder?
Thanks for saving us all Sideshow!
Powered by Cu
Old 10-21-2011, 01:58 AM
Zedn's Avatar
Originally Posted by Doubledip View Post
Service # 12625455
or
Service # 12633238
its 12612384
eBay Australia: Buy new & used fashion, electronics & home d�r
Old 10-22-2011, 12:17 AM
That number is for an 08 ish motor
I always trust everything I read on eBay
Hehehehe
I would send the person an email and ask what year is the tune
In it
Also ask him what butterfly u should use
Let's hope they know their **** cause a lot out there don't
I have a std silver butterfly and a std brass butterfly throttle bodies
But after tomorrow I can't access them for 2 weeks as they are in a container
Up to qld
my website
  #33 (permalink)
Old 10-22-2011, 12:30 AM
Zedn's Avatar
Im a long way off yet. When the time comes i will plug it in and see what happens.
  #34 (permalink)
Old 10-22-2011, 12:55 AM
Cool
If u have wrong throttle body to the ecu u prob won't
Notice much till u give it a lot of throttle on the road
So just finish it and take for drive then worry then
Hopefully things will be easier to get registered by then
Hehehe
my website
