Old 01-15-2012, 11:12 PM
Merv and Sharon's Avatar
I have just ordered a couple of the silicone hose ones from Mike, as backs ups for the one I have. Thanks Leigh.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 01-15-2012, 11:30 PM
Rick Parker's Avatar
byroncobra: Use a tapered pipe plug, these are commonly found in the plumbing dept of the hardware store or home suppley depot. The water pump can be threaded without removal from the engine. Put heavy grease on the tap and clean the filings from it as the internal threads are being cut. The few that fall in the pump will not hurt it. Depending on the pump you have, the nipple in question may be a press in or part of the casting. If it is part of the casting, you may be able to thread the interior of the nipple for a plug or it may have to be cut off and dressed first before threading. Some aftermarket pumps actually use nipples that are threaded and can be unscrewed and a plug put in their place.
Old 01-16-2012, 04:46 AM
Mando's Avatar
Byroncobra, I'm positive, you can see both ports in the following picture.
Regards.
Mando
Old 01-16-2012, 02:42 PM
byroncobra's Avatar
All good stuff thanks.
I might have a gentle go at unscrewing the nipple first, Mando yours looks so neat (what a surprise)
Then look a plan B and C
Greg
Old 01-17-2012, 03:05 AM
I'm pretty sure that the hose ends are pressed in on a 302 and a 351. In my old Cleveland I grabbed them with a vice grip ( crushed them to hell ) and removed them by screwing back and forward and pulling them out. I then machined up a pair out of stainless steel with a considerably heavier wall thickness. I doubt you could cut a thread on the original nipples.
