Good on ya Baz, You've gotta make it feel like a Military jet taking off !!!
I've got a Comp Cams Hydraulic roller cam and found (the hard way) that it needs a special 'Hard' distributor drive gear.....give ICE ignition a call ...Michael Konstandinou on 03 9532 6000 . They make their own super hard drive gears. I have one now. |
Have you got a distributor in yours Baz? GM hides em' well under all those covers ;)
BTW, what cam are you fitting? I have a Comp Cams '232/234 xtreme XE-r' in mine, great cam, but you will need to fit a stall converter. Is the converter you have now a stockie? |
Baz |
That will be a great choice for a street cobra Baz.
Valve springs are a necessity IMHO. Give Dominator converters a ring, they will need to know the weight, diff ratio, cam specs ect of your car and will build you a converter to suit. You will be dissapointed with your new cam if you don't, it'll bog down off the line and will be doughy to drive. A stall converter will allow the engine to flash up to the revs at which your cam will start to make power. I'd think you would want about a 2500-2700 rpm stall speed. The TCC (torque converter lock up) can be retained too. |
The factory converter will have been designed for an 1800KG car. When installed in a 1200KG car the stall speed will be even lower. Car weight is a big factor in torque converter setup. I reckon a dialed in high stall converter would be a good thing to have even with a stock cam in a Cobra.
Cheers |
very interesting mike and others.
now that i have something to play with in the shed i shall play.! |
| All times are GMT -7. The time now is 04:42 AM. |
