Old 06-07-2012, 10:52 PM
PeterAllen's Avatar
Default Rivnut tool - el cheapo?
I'm after a rivnut tool for my build - I anticipate no more than 100 applications - he said hopefully! I couldn't see any in Oz and there are $30 tools on USA eBay with $30 postage. I've previously purchased some good value sheetmetal tool in this price range (jogglers, etc) but I was just wondering if anyone has purchased these? Thanks
Old 06-07-2012, 11:40 PM
leroy17's Avatar
I purchased one from local nut and bolt shop which was a solid cast construction and it works a treat.... $80-.
I have used one which looked like it was made of folded sheet steel.... still worked...... but the cast one was much nicer to use.
Just my observations.
Old 06-08-2012, 12:48 AM
sambo's Avatar
There's several on eBay (Aussie) for under $100 delivered. Use "nutsert" as your search term.
Old 06-08-2012, 01:08 AM
PeterAllen's Avatar
Excellent - many thanks.
Old 06-08-2012, 04:31 AM
renovationinnov's Avatar
if you have a tradetool in your local area try them i bought one [ there own brand for $35 gun only / then the rivnuts are about $25 from memory for 6mm
hope this helps
rob
Old 06-08-2012, 05:03 AM
Modena's Avatar
I bought mine in a kit-box with various nutserts and fittings, was about $120 from memory, I think it has 3,4,5,6mm fittings, got it from Cost Less Bolts. Seems good quality, some Euro/German brand.
Ben in AU
Old 06-08-2012, 08:03 AM
bobcowan's Avatar
10-15 years ago I bought cheap set from Harbor Freight. I'm still using it. The kit cam with aluminum insert. Throw those away, and use a better quality material
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 06-08-2012, 11:09 AM
Cobra Make, Engine: ERA FIA
I got one for about 12 bucks from aircraft spruce. It's a manual job you use with a wrench. Other than being a little slow it works fine. I've probably installed about 75 nuts with it.
Old 06-08-2012, 02:06 PM
FWB's Avatar
FWB FWB is offline
when we do any of those type of fasteners here, in my shop( USA) i always go for the PEM brand, if you have access to that brand, they are good quality.
Fred B
Old 06-08-2012, 09:44 PM
Rick Parker's Avatar
Some of the individual size kits with 6-10 rivnuts have their own installation tool included and allow for a well installed insert and the tool is fully reusable.
Old 06-08-2012, 10:55 PM
OZCOBRA's Avatar
A niffty NUTSERT accessory FOR THE LAZY ...
$125.00 http://www.ebay.com.au/itm/RIVET-NUT...ht_2120wt_1037
