1Likes
Post By Aussie Mike
01-15-2013, 10:03 PM
VIC
Oil cooler plumbing
I've been enjoying myself lately. Things are so much easier to work on with the body removed.
I bought all the bits to plumb in an oil cooler ages back. I finally pulled finger and got it done.
First thing to do was to mount the cooler. I ended up welding a couple of tabs to the front cross member in front of the radiator. This puts it in a good spot to be in line with the lower grill opening.
It's an Earls brand cooler but in the same pattern/size as the original Mocal one. The fittings on it are AN#10.
With the Cooler in place it was easy to route the hoses in and cut and terminate the hose ends.
I've added a couple of extra clamps since this pic
To connect it into the motor I picked up a Mocal LS1 adapter. This connects to a couple of ports on the sump that are already in place (probably designed exactly for this type of thing). The adapter also incorporates an oil thermostat so that it bypasses the cooler untill the engine oil gets up to temp.
It's worked out neat and tidy and all the lines are easy to get to but up out of the way.
Mike Murphy
Melbourne Australia
01-15-2013, 10:20 PM
NT
Hey Mike, Can I ask where you bought the oil filter adaptor from?
Looks tidy.
Cruising in 5th
01-15-2013, 10:25 PM
VIC
The cool thing is the adapter doesn't change anything on the stock filter setup. It just bolts to the side of the sump in place of a little bypass plate that the factory install.
I got it from Improved Racing:
Improved Racing | Adapters & Thermostats
The've got a new billet version now.
Mike Murphy
Melbourne Australia
01-15-2013, 10:43 PM
NT
Is that the type that includes a thermostat?
Cruising in 5th
01-15-2013, 10:47 PM
VIC
I think there is a thermostat and non thermostat versions
Mike Murphy
Melbourne Australia
01-15-2013, 11:11 PM
NT
They advise wont fit on front hump sumps like mine, is there a possable clearance issue you can see with yours? (I know you have rear hump)
Cruising in 5th
01-15-2013, 11:14 PM
VIC
I've got a front sump at home. I can check it against that and see if you like. It may have problems clearing the engine mount or the alternator on a front sump.
Mike Murphy
Melbourne Australia
01-15-2013, 11:52 PM
NSW
Nice work.
Is that a little port for an oil pressure sensor also? Looks like a neat little package.
01-16-2013, 12:41 AM
VIC
Originally Posted by Zedn
Nice work.
Yep, I already had my oil pressure gauge plumbed into that point so it's just a matter of putting an AN# fitting in there and connecting the hose from the gauge.
You can also see in this pic the plate you remove to bolt the oil cooler adaptor on.
Mike Murphy
Melbourne Australia
01-16-2013, 03:02 AM
Vic
Remote oil units
Mike,
I use the same one, great service ( Improved Racing ) and bolt
on fittings... cannot go wrong.
STIFFY
01-16-2013, 03:51 AM
Vic
very tidy Mike, nice.
Ben in AU
01-16-2013, 06:46 PM
Vic
Box meister,
Dont get the one Mike has, it wont fit the LS1 style front sump, it interferes with the alternator, or the engine mount depending which way you orientate it.up or down, Gregg and I have experienced this first hand.
Improved racing do make an adaptor specifically for the GTO, Holden front sump fitouts, even stating Holden Commodore and Monaro LS1 on thier site,
This is mine fitted, part number IR-EGM-1007
includes a 1/8th NPT ports for pressure and temp.
http://www.improvedracing.com/adapte...-pan-p-82.html
comes in two versions, -8AN and -10AN
regards
"the other Dave"
Reason: added in link to improved racing part
01-16-2013, 07:38 PM
VIC
There you go. Good pic Dave.
I bought one similar from Proflow ages back. The only issue I had with it was it didn't have a thermostat built in. I bought an external thermostat and was all set to go but then I saw the Mocal one with all in one.
I now have a very nice Earls oil thermostat that I'm thinking of selling. Same as this: Earl's Performance Products Engine Oil Thermostat 501ERL - SummitRacing.com
Before these neat adaptors were around I machined up a low profile filter adapter that Phil N was using.
He has an external filter setup but I think he's switching to one of the new adapters now too.
Mike Murphy
Melbourne Australia
01-16-2013, 07:40 PM
NT
Cheers Dave, I was not sure if being in a Cobra would allow for more room to run hoses and clear items etc?
Sounds like probably not.
Does that one have a built in thermostat?
As a good mate is the local Aeroflow rep and i can get one at cost price through him. But no thermostat built in.
Cruising in 5th
01-16-2013, 07:42 PM
VIC
Originally Posted by stiffy
Mike,
STIFFY
I agree, they were good to deal with.
I think Ben Gosper (Fanta Orange CR Cobra) bought one of their baffle kits. I remeber seeing it and think it looked pretty good.
Mike Murphy
Melbourne Australia
01-16-2013, 07:51 PM
NT
I have a baffle kit to fit at some stage, Ben bought a few in at same time.
Cruising in 5th
01-16-2013, 10:36 PM
Vic
Dave,
Have you experienced oil starvation problems with the front sump?
Mike,
The Improved Racing adaptor for the front sump version doesnt have a thermostat in it, I bought the Mocal version which i will mount to the chassis, it has a by-pass in it when the oil isnt up to temp, Comes with a reasonable mounting bracket.
Dave
Mocal Remote Oil Cooler Thermostat
01-16-2013, 11:01 PM
VIC
Looking good Dave.
Mike Murphy
Melbourne Australia
01-16-2013, 11:16 PM
NT
I havent as of yet (I must be driving too slow)
Cruising in 5th
