Like Tree6Likes
  • 4 Post By Mando
  • 1 Post By BMK
  • 1 Post By Mando
Old 02-22-2013, 10:22 PM
Mando's Avatar
Default Where can I buy from?
I'm hoping someone can let me know where I can buy a new "AC Cobra Weber Intake Manifold Neck".
I've tried Cobranda and Cobra Restorers but no luck.
Any ideas?
Regards.
Mando
Old 02-22-2013, 11:15 PM
750hp's Avatar
Inglese sell them with their complete packages, so I guess they'd sell them separately.
8-Stack systems
Craig
Old 02-22-2013, 11:36 PM
Mando's Avatar
Thanks, I've sent him an Email.
Regards.
Mando
Old 02-23-2013, 12:27 PM
mickmate's Avatar
Do you want the cast ally Cobra lettered ones or one made as they were from steel tube?
mickmate
http://www.actoncustom.com/
Old 02-23-2013, 01:15 PM
Mando's Avatar
I'm after the cast alloy one.
Regards.
Mando
Old 02-23-2013, 03:47 PM
mickmate's Avatar
Tony has them listed is he out of stock?
AC Cobra Weber Intake Manifold Waterneck
mickmate
Old 02-23-2013, 09:02 PM
DaveW's Avatar
Mando,
What skulduggery are you up to?, i cant see anywhere i would want to mount that in your engine bay!
Dave
Old 02-24-2013, 12:01 AM
Baz's Avatar
Baz Baz is offline
Regards.
Hey Mando - Don't swap the Morrison Injectors for Webers. I feel that would be a big backward step.
What problems are you having with the Morrison setup?
Baz
Old 02-24-2013, 01:43 AM
Mando's Avatar
Well, where do I start?
I have just finished pulling my motor out due to overheating because my cooling system wasn't up to scratch.
I'm also in the middle of replacing every red/blue fitting on the car with silver/black fittings. Fortunately I found out through AussieMike that the constant petrol smell in my garage was due to the braided hoses I used on my fuel system giving of petrol vapor. I contacted speedflow and they confirmed that after about 3 months braided hose absorbed the fuel and let of petrol vapor when using 98 octane fuel. I didn't mind the petrol smell in the garage but I couldn't use the air conditioner without getting petrol fumes through my whole house.
I'm not changing the injection system. The reason for the weber manifold is that I'm going to run the two ports at the front of the intake manifold to the weber manifold which will run to the radiator. I'm also installing a Harrison tank.
While all this is going on I've decided to change a few things that I've never been entirely happy with including
=new boss rocker covers.
=new dipstick.
=reposition the alternator about 50mm lower by redesigning the alternator bracket.
=changing the rubber braid to teflon braided hoses for the fuel system.
=weld a bung to the bottom of the radiator to be able to drain it easily.
=install an air bleeder to the top of one of the water hoses.
=running the overflow from the catch can that picks up the rocker cover fumes to the petrol pump position on the timing cover. [AussieMike's solution].
Regards.
Aussie Mike, Gav, Baz and 1 others like this.
Mando
Old 02-24-2013, 07:56 PM
BMK's Avatar
BMK BMK is offline
Mando
Come on your just concerned someone will light a cigarette in the garage...
Rog246 likes this.
Bernie Knight
Old 02-24-2013, 08:21 PM
Mando's Avatar
I only know 1 person that would do that!
Do you have a mirror?
Regards.
Rog246 likes this.
Mando
