2Likes
Post By Zedn
Post By Treeve
04-12-2013, 07:38 PM
qld
position of roll bars
help guys i'm just starting to set up to drill holes for my rollbars ,& as its a venom motor sports
yes a mr tuckers I have no reference points to go on accept 100mm from inside edge of rear cock pit [ rear fire wall ]
so do I pick centre of head rest or slightly off centre
what lay back on the hoops
level to top of wind screen ? FOR HEIGHT
as its raining// so I can dummie fit, SO as to get them cut & welded thanks a head
ROB
04-12-2013, 08:01 PM
vic
If you want to race it, 50mm above your helmet is the go.
Depending on your seat height that may look a bit high though.
Powered by Cu
04-13-2013, 12:39 AM
NT
Mine sits "high" as I wanted the 50mm above head height.
Here is an old pic showing height with original seats when I attended my first Nationals.
Cruising in 5th
04-13-2013, 03:19 AM
VIC
My understanding is that you should draw a line from the top of the roll bar to the top of the front mud guard and your helmet should be under that?
Dave - you need to slouch when you roll over
Me I am a short arse so mine is ok :-)
Reason: added comment about shortarse
04-13-2013, 03:58 AM
NSW
Why? Your fibreglass guards won't hold up the front of the car
04-13-2013, 04:42 AM
VIC
True, I hadn't thought about that
04-13-2013, 04:37 AM
qld
thanks for your in put but i need to know where to put the holes & what spaces are needed ? what lay back on the hoops
if you have pics that would help
thanks ROB
Vic
Rob does your chassis any provision for mounts already, or are you truly starting from scratch here? I can go get some details off mine, just want to know what exactly I should measure.
Ben in AU
04-13-2013, 05:56 AM
I think the angle they lay back is 8 degrees.
04-14-2013, 01:18 AM
qld
Modena as you know we have no mounting point on the chassis .. so yes from scratching of head does apply
wazza thanks 8 degrees helps a lot
now centre of seat area or just off centre .. hoops I have are 298 mm centre/ centre of 50mm x4mm alloy hoops
thanks ROB
04-14-2013, 05:44 AM
NT
For looks it would be good to centre behind seats
Cruising in 5th
04-14-2013, 06:10 AM
NSW
Cobra Make, Engine: Dax
Guys,
Here's the link to the CAMS regs for roll bars / cages. The 50mm detail is on page 12. Good information is worth it's weight in saved money through re-work.
http://www.camsmanual.com.au/pdf/10_...e_J_2013-5.pdf
Treeve
04-14-2013, 06:59 AM
If you're building a replica Cobra....build it to look like a Cobra.....
If you are building a race car...then you should follow the CAMS guidelines.
04-14-2013, 03:37 PM
NT
My opinion too Wazz, if building a race car, build a cage.
Cruising in 5th
04-14-2013, 04:22 PM
When too many bars is never enough.... Just chuck a few extras in for good measure!
04-14-2013, 09:32 PM
Mattyboy...looks like the new rollercoaster at Dreamworld
