Like Tree6Likes
Old 04-12-2013, 08:08 PM
Gav's Avatar
Gav Gav is offline
Default The taxi motor is dead
It is with a heavy heart that I have to report that my taxi motor has died.
I started testing things last night (optimistically) hoping that it had a couple of dud valve stem seals, after putting compressed air into #8 and having the bulk of the compressed air go straight into the sump I can now conclude that it has no longer got compression rings or complete pistons in 3 of the 8 pots.
All is not lost though, I have Boxy looking around in the outback NT for a suitable replacement or there is always Ebay...
Powered by Cu
Old 04-12-2013, 09:21 PM
Cobra Make, Engine: Python
Not good Gav, what sort of work was it doing when you noticed the issues ?
Sounds like a good oportunity to return to a more 'traditional outfit' ?Either way Im sure you and Boxhead will sort it. It was a pleasure meeting you both at Shelbyfest this year.
Chris & Melissa
Old 04-12-2013, 09:40 PM
Gav's Avatar
Gav Gav is offline
After the last session on the Saturday at Shelbyfest, it was missing cylinders on the passenger bank and would not idle.
The poor thing had to scream 'ENOUGH!' at some point.
I think Dave has found something usable for a replacement though
Great to meet you two too, are you back on the road yet?
Powered by Cu
Old 04-12-2013, 10:55 PM
Modena's Avatar
We can rebuild him, better, faster, stronger
Ben in AU
Old 04-12-2013, 11:33 PM
Gav's Avatar
Gav Gav is offline
Forget the $1Million dollar budget though!
Powered by Cu
Old 04-12-2013, 11:48 PM
letsboogie351's Avatar
Cobra Make, Engine: Kenmer with Ford Quad Cam Boss 260
"All is not lost though, I have Boxy looking around in the outback NT for a suitable replacement or there is always Ebay..."
Jeeeeesus Gav!
Going on past history Boxy is likely to find an old slant six for you!
Old 04-13-2013, 12:21 AM
boxhead's Avatar
I have got you covered Gav.
I found these out behind teh shed, if your bores are all good we can slap another stock bottom end in it for you.
I will degrease them and blow them dry so they are ready to fit, I think even the rings are still pretty good.
Or if your bores are shagged, I pulled this out of an old ****ter a while back.
I will get the wiper sniper out first then hit it with degreaser, should be good to go as it is, as the car that it was in stopped due to a smash and roll over, not an engine failure, probably go back and get the gearbox too if you need that?
Cobra01 likes this.
Cruising in 5th
Old 04-13-2013, 12:24 AM
Legless's Avatar
Cobra Make, Engine: DRB 302 Ford HO Block
Bummer Gav!
After a few goes round the clock even taxi motors can tend to get a bit smokey.
Old 04-13-2013, 12:28 AM
Gav's Avatar
Gav Gav is offline
That will be AWESOME Dave!
The trans will probably be OK due to being preseved in that dry forgiving climate.
Be carefull not to clean off the dirt on the long motor though, patina is very important to me.
Powered by Cu
Old 04-13-2013, 12:30 AM
Gav's Avatar
Gav Gav is offline
Thanks Legless, imagine how fast it could have been...
Powered by Cu
Old 04-13-2013, 12:48 AM
boxhead's Avatar
Ok, I will just cut the grass back a little first (to be sure no snake has made it home) then I will stick it on a pallet for ya.
Gav likes this.
Cruising in 5th
Old 04-13-2013, 12:50 AM
Legless's Avatar
Gav,
I'm sure Dave will do you a good deal, freight may be a killer though.
Old 04-13-2013, 12:51 AM
boxhead's Avatar
Crap, there was a snake in there.
Gav, Legless and Cobra01 like this.
Cruising in 5th
Old 04-13-2013, 01:12 AM
just fix it
Old 04-13-2013, 01:20 AM
Gav's Avatar
Gav Gav is offline
It seems that all snakes not just Cobras prefer Chevs?
Powered by Cu
Old 04-13-2013, 01:21 AM
tomcat racing's Avatar
Cobra Make, Engine: Some kind of FORD thingy, with several pis tins, twin chain driven SUs feeding a Y block, apparently.
Default Rip
What was that about all that barking i remember hearing about how these chevys NEVER break down, OH so reliable, etc etc.
Nuts,,, Bolts,,, and 2 smoking barrels.
Old 04-13-2013, 01:23 AM
Gav's Avatar
Gav Gav is offline
Just to rain on your parade Tommy,
It didn't break down, it is still running, abeit with a missfire or two or three...
Powered by Cu
Old 04-13-2013, 01:25 AM
boxhead's Avatar
And you wont need to spend a squilin dollars to make it win at Shelbyfest again.
Cruising in 5th
Old 04-13-2013, 01:28 AM
Gav's Avatar
Gav Gav is offline
I reckon a flaggin of dry sherry should see us even Dave?
Powered by Cu
Old 04-13-2013, 01:35 AM
boxhead's Avatar
Or a Roo tail and packet of durries.
Gav likes this.
Cruising in 5th
