Like Tree6Likes
Old 05-30-2013, 03:45 PM
hp1050's Avatar
Cobra Make, Engine: Harrison, Supercharged 1UZFE
Neutral
Default Harrison Front Brakes
I need a little help I have a Harrison Cobra with the commodore front end in it, I want to upgrade the brakes and assume that they are commodore brakes and rotors? If they are commodore what model are they VB/VC? Thanks
Old 05-30-2013, 04:02 PM
boxhead's Avatar
Neutral
I am not a Harrison guy, but I think I read somewhere that they use the VT/VX type front end.
I am sure a builder will pop in soon enough.
Cruising in 5th
Old 05-30-2013, 05:32 PM
Wazza's Avatar
Standard brakes on the Harrison...VT Commodore.
Phone Warwick on 0450 801086 for any other info...
He also has some pretty awesome "upgrade" brake packages ( 6 spot) available,if you're interested.
Cheers.
Warren.
Old 05-30-2013, 07:46 PM
Cobra Make, Engine: Manufactured by Me, 408 Windsor, TKO600, 3.3 Jag rear
Default Avaliable brakes
Hi,
I have a set of near new 2000Kms old VT/VZ rotors and Calipers that I took off my Daytona so I could fit the Harrop big brake upgrade. Included are standard disk pads and Green Spot pads that I used once at Winton for a day.
Im in Melbourne so if interested, PM me as they are sitting unused in my shed
Serpnt
Melbourne
Old 05-31-2013, 04:02 AM
Mrs flatchat's Avatar
Wink
if all else fails -- go to :- Hoppers Stoppers Big Brakes disc brakes performance repairs upgrades Australia Custom Car Restorations Corvettes Mustang Ford Holden Plymouth Chev Impala Chevrolet Dodge charger valiant fj lo-riders hot rods car detailing brakes hop-up customising VT
Old 05-31-2013, 04:48 AM
The GM sliding calipers are a poor option, when coupled with the Nissan Skyline twin pot rear calipers. A budget upgrade would be to use the Skyline fronts as well.
I have R33 GTST "Sumitomo" calipers on 310 dia rotors with EBC red pads and car stops great ! The balance was perfect on the rollers, when the car was registered.
I used Ford Territory rotors ( DBA 2107 or RDA 7934 ) Skimmed about 10mm off rotor overall diameter. 12mm adapter plate locates caliper on VR Commodore hub ( re-drilled for ford stud pattern )........was dead easy. I have a cad file for the adapter plate drawing.
Murray
Old 05-31-2013, 09:26 PM
byroncobra's Avatar
that's what I've got........seems to stop alright
Old 06-01-2013, 12:59 AM
Merv and Sharon's Avatar
I got AP Racing calipers from Sydney and they were easily fitted and the difference was enormous. Some pics in my gallery. Others have used the Nissan fronts with success.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 06-03-2013, 12:56 AM
Cobra Make, Engine: Harrison build #98 with Supercharged 6.2L of Chev Power, TKO600 5 speed gearbox
I got some AP racing 4 pots on the front, stop extremely well. 17" wheels as well though.
Old 06-03-2013, 12:03 PM
Krait's Avatar
Neutral
+1 for AP's, have them at both ends though.
Geoff
Old 06-03-2013, 04:33 PM
sambo's Avatar
You guys with the AP brakes must have some seriously sticky rubber. My tyres let go well before I reach the braking limit with the standard Commodore brakes. Kumho Ecsta KU31s.
Old 06-03-2013, 04:58 PM
400TT's Avatar
Sambo, I would expect these guys are changing front calipers to units with more suitable piston sizes to optimise the front and rear brake balance.
I know the skyline calipers have a lot smaller piston area than the 2-piston PBR units.
Same deal with Jag brakes, you want to fit a front caliper with smaller piston area to get more rear brake bias.
Even fitting a 2-piston PBR instead of Jag 4 piston improves the brake balance.
Sambo, what is your brake balance like?
www.absolutepace.com
Old 06-03-2013, 05:59 PM
sambo's Avatar
Craig, my Cobra originally failed the brake test with the standard Harrison setup. But rather than downgrade the front brakes I replaced the rear brakes with larger units from the Holden Camira. I paid for the full brake test under VSB 14 and passed with flying colours. Brake bias is all good now.
Old 06-03-2013, 06:46 PM
400TT's Avatar
Great to hear mate. Sounds like you have a really nice brake setup now.
To answer your original question, for a street car, no you don't need anything more.
Old 06-03-2013, 08:03 PM
07cob's Avatar
Paul
Did the Camira brakes make much of a difference to the braking performance? Obviously helped with the test but I am wondering if it helped on the road as well.
Geof
Old 06-03-2013, 09:02 PM
sambo's Avatar
Yes, definitely Geof. With R33 calipers the rears were not locking up soon enough under aggressive braking tests - now fixed. The nose of the car was also diving under brakes, whereas now the whole car hunkers down evenly. The brake pedal is also more progressive than before - not surprisingly.
Old 02-04-2014, 10:17 PM
sambo's Avatar
Resurrecting another thread here. I came across this interesting big brake upgrade suitable for the VT Commodore front end, which is in the Harrison.
VX/VZ/VT/VY 6 piston front/4 piston Rear Brake Budget Mounting Solution!
A 355mm rotor and calipers probably wouldn't fit inside my 17" wheels.
Old 02-04-2014, 10:54 PM
gjkrv8's Avatar
very tempting Sambo. But I too only have 17" rims - :-(
one day I will get round to it. cheers Gregg
Old 02-05-2014, 12:36 AM
sambo's Avatar
G'day Gregg. After a bit more research it appears we can go up to 330mm with 17" wheels. There are a number of 4 and 6 pot kits on eBay to suit VZ - search for Ksport or D2. These are probably made in China and not ADR compliant, which puts me off.
Next one I came across was a VF-spec upgrade kit with 322mm rotors, ebay item 181218009835, pictured below. Only twin piston but looks like a different design to the earlier calipers and the larger diam rotor will help.
A couple of places are selling an Alcon kit with 335x28 two piece rotors, 4 piston calipers, adapters, etc.
D2 Coilovers - Fifteen52 Wheels - All at Tuner Warehouse - Alcon Brake Kit Sale - 4 Spot Monoblock 335mm Kits just $2500
Brakes Direct - JANUARY SALE: Alcon 4 Piston Caliper Upgrade Kits! / News
This video taught me a few things and features the Alcon rotor:
Plenty of suitable AP / PBR / PWR kits here:
Holden - Performance Spares
Also found a "PK1" kit on eBay using VE calipers and another "BAER Pro" 6 piston kit with added bling, below. Enough options?
Rog246 likes this.
Old 02-05-2014, 12:53 AM
Ooh also while this thread is up - I hear you can use stock VT fronts and upgraded brembo calipers and rotors from the R33 on the rears, someone told me there was a model that came with brembos stock? Wondered if anyone knew anything about this or what model R33 they came off?
