Old 08-14-2013, 04:53 AM
Aussie Mike's Avatar
Default CR Bump steer kits now available
Hi All,
I've been busily working away in my machine shop and have just finished another batch of rear bump steer kits for the Classic Revival Square tube chassis.
These two kits are being posted off shortly but I'm made extras and have a few on the shelf.
The kits use high quality Chrome molly rod ends (left and right threaded for easy adjustment). The rod itself is TIG welded chrome molly tube. The clevises are machined from bright steel hex bar to close tolerances. The kit comes with all nuts, bolts, washers and machined spacers. All top quality hardware.
The kit make a dramatic difference in how the Square tube chassis handles. It makes it feel a whole lot more stable and planted. There's plenty of guys on here that are already running them with good results.
I've bolted up my old AU arms so you can see how the kit installs.
Drop me a PM or an email if you need one.
Mike Murphy
Melbourne Australia
Old 08-14-2013, 04:02 PM
Gav's Avatar
Gav Gav is offline
I can assure any potential customers of Mikes that his gear works.
I have one of his early rear kits and it fits and works a treat.
Looks loads better than the factory crap too!
Powered by Cu
Old 08-14-2013, 05:47 PM
Philm's Avatar
Default Home grown Brilliance
I also run Mikes Bump steer kit on my cobra.
The quality of the kit is outstanding and this mod really transforms the car.
This is a must have for any square tube chassis CR.
Phil
Old 08-15-2013, 03:00 AM
BMK's Avatar
BMK BMK is offline
Also makes the best side pipes.....
Bernie Knight
Old 08-16-2013, 05:13 AM
boxhead's Avatar
I have a set of the rear bump steer arms. The difference is chalk and cheese.
I also have a set of Mikes side pipes, great bit of gear and you can "tune" them to be as quiet or as loud as you won't.
Cruising in 5th
