Old 03-08-2014, 03:53 AM
albanycobra's Avatar
Default 302 8 stack 4sale
Hey Fellas
i have a 8 stack to suit a 302 / 5.0L that i dont need. Changing motor to 351 stroker so had to buy another 8 stack to suit.
Comes with fuel rails and cross over fuel line. Can supply vid of engine running with 8 stack if required. runs on a stock engine and sounds awesome.
$1800 ono.
Old 03-08-2014, 06:01 AM
boxhead's Avatar
I might be keen on this, will know after next weekend.
Cruising in 5th
Old 03-08-2014, 06:40 AM
boxhead's Avatar
Can you advise throttle diameter? 40, 45, 48mm?
Cruising in 5th
Old 03-08-2014, 12:37 PM
Z-linkCobra's Avatar
Im confused. Those look like 302 valve covers yet the distributor is in the back. Am I just seeing it wrong?
Old 03-08-2014, 01:05 PM
dhs.buckley's Avatar
Cobra Make, Engine: Python ford 302 ho, 4 speed toploader, jag irs 3.54
I would say it's a GT40 so dizzy at the front.
Does the 8 stack come with a computer?
I would love this, but what is needed to run the 8 stack?
would i have to change exhaust manifolds to run oxy sensors?
Old 03-08-2014, 03:13 PM
More details please, whose system is it, its specs and what type of Brain is running it?
Chris L
Old 03-08-2014, 05:51 PM
the throttle bodies are 50mm. Not sure on brand.
http://stackinjection.com.au/main-gr...-manifold.html
It comes with the following
1 intake manifold to suit 5.0l / 302 windsor
8 throttle bodies
8 ram tubes
2 fuel rails
1 throttle cable center linkage
I have this set up on a completely stock 5.0l. I am using a Microtech lt16 ecu, msd 6al and a mallory dual sync dissy. motor runs really well and sounds awesome at revs.
The reason why i chose Microtech was the fact they set the ecu up with the desired crank sensor at the factory and then send you a package you install and starts up easy.
Old 03-08-2014, 06:47 PM
Dwight's Avatar
Smile
If it's like my Eight Stack system it will support 500 hp. Total of 1000 cfm, I think.
Dwight
Old 03-09-2014, 07:07 PM
The 8 Stack is sold.
