Like Tree4Likes
  • 1 Post By Mrs flatchat
  • 1 Post By deano59
Old 06-12-2014, 04:55 AM
Mrs flatchat's Avatar
Smile Flywheel remachining
In case anyone needs to know
1st step - Set up in machine true to crankshaft bolt up face
2nd - A clean up pass - to uncover wear, damage, hot spotting and heat checking (cracks) etc --caused by worn / slipping clutch.
3rd - Machine until these marks disappear, usually about 1-1.5mm --any more than 5mm is probably time for a new FW.
4th - A cross hatch swirl pattern is applied to help the clutch bed in
5th - Deburr holes, retap threads, fit dowels if required and thoroughly clean.
Tips:- Wash Fly Wheel and clutch Pressure plate faces with a solvent to thoroughly remove any trace of oil, grease, wax or protective coatings.
Torque down clutch cover bolts evenly, paticularly on steel flywheels and use a smear of never seize on the bolt threads -as they have a habit of "firing" up (seizing) -especially if done up with a power wrench
jcraigau likes this.
Old 06-12-2014, 12:37 PM
07cob's Avatar
Mr F
Looks like new! What did you use to get the crosshatch pattern?
Geof
Old 06-13-2014, 04:29 AM
Wink
Trade secrets Geof --
better than new and finished with a 4" ceramic bonded sanding disc (skillfully applied of course)
Old 06-13-2014, 06:18 AM
ive been using a friends engine room to build my new race engine in nice sterile environment and I see him do about 4 or 5 flywheels a day . I like watching the crank grinding machine best of all . I think I could move in and live at his engine recon shop lol.
renovationinnov likes this.
Old 06-13-2014, 03:55 PM
Wink
Live in a machine shop - thats sick Deano -although most machine shops need someone to clean and polish the machines
Its imperative that the "hot spots" or surface hardening is completely removed -- the lathe is most efficient at this.
The planetary surface grinder is not the best for (performance) flywheels,
The process would take ages to grind out 1mm and using a magnetic chuck which stresses the surface out of shape also.
deano59 likes this.
Old 06-13-2014, 04:16 PM
PeterAllen's Avatar
Does resurfacing require removal of the crankshaft for rebalancing?
Old 06-13-2014, 07:40 PM
Wink
Not usually -- some shops can do a premachine balance check of the FW, then an after machine balance validation of same
ie:- if it had an imbalance it would be brought back to the way it was presented
PeterAllen likes this.
