Like Tree3Likes
  • 1 Post By Aussie Mike
  • 1 Post By PeterAllen
Old 07-19-2014, 09:58 PM
PeterAllen's Avatar
Default Bonnet (hood) frame designs?
My GTO front section was laid with the bonnet included - there was a groove indicating where a cut was to be later made to separate the items. I initially thought this was a clever idea as it would ensure alignment; as it has turned out, it's not.
With no strengthening lip/return on the edge of the bonnet (nor have the front guards for that matter), and a likely 15-20 year passing since it was cut out, I now find the longer edges don't match up at all - something like an 8mm bow.
I'm trying to decide on what design of rib or frame I need to fibreglass/attach to the underside of the bonnet to pull it into shape.
I would appreciate any comments and photos which indicate what others have done to ensure the stability of the bonnet shape. Thanks.
Old 07-20-2014, 01:13 AM
Just a suggestion...Make a wood "spine" to the correct curve. clear of the edges. Then glass in a reinforcing lip...thick. That might hold the bonnet to its correct shape.
Metal ribs glassed in could work also.
Old 07-20-2014, 01:43 AM
on the fibreglass panels on our race car I glass hessian strips into the panel it makes them quiet stiff.you can buy it in rolls from craft shops or ebay
Old 07-21-2014, 05:42 PM
PeterAllen's Avatar
Rob. The bonnet is the best part of 5mm thick (?) and I think it would need a very substantial rib. I would also be worried about the long term adhesion to the existing material if under constant stress.
Dean. Kinda as above. My problem is compounded by the substantial amount of material already in the bonnet.
I think I might attach a rib to the existing bonnot to give it a new (correct) profile and then make a mould and pop out a new bonnet incorporating ribbing or hessian.
I HATE BODYWORK...
Old 07-21-2014, 08:07 PM
Aussie Mike's Avatar
Originally Posted by PeterAllen View Post
I HATE BODYWORK...
I can heartily agree with that statement. I'm happiest, welding, machining and turning spanners. Sanding and filling sucks.
deano59 likes this.
Mike Murphy
Melbourne Australia
Old 07-21-2014, 08:52 PM
xb-60's Avatar
Is it feasible to add one or two (adjustable?) supports along the length of each side of the bonnet opening so that it's correct shape when shut? Sure wouldn't have any rattles.
Glen
Old 07-21-2014, 08:59 PM
Have you looked at using heat to reshape the bonnet curve. I believe Andrew Cornett had some success straightening out the sills on his CR using clamps and heat.
Mike Murphy
Melbourne Australia
Old 07-22-2014, 07:28 PM
PeterAllen's Avatar
A bit of a rethink.
I removed the front section and positioned the bonnet using some clamps I made up - similar to butt weld clamps. It all aligned pretty well which means the opening for the bonnet is the problem. It seems that when I flared the guards to match the sill I should have ensured the bonnet opening didn't distort, which it has. Arrrr...
I'm going to lay some fibreglass rope along the edge of the bonnet and juxtaposed along the guard while the bonnet is clamped in position and the front section off the car.
If, when I refit, the front section doesn't align with the mounting points on the unibody you will hear me scream wherever you are.
guye likes this.
Old 07-23-2014, 02:02 PM
Cobra Make, Engine: Evans chassis, jag fr. & rear.
Try this,
Mount the nose cone on the car. Make a couple of ribs to go right across the underside. One at the front near the light holes, one or two near the middle and one at the rear. Glass these in place. Remove the nose cone and invert. The ribs will hold the shape of the cone in relation to your chassis. Then do your bonnet. When the bonnet is finished remove the ribs. I have a good trick for glassing upside down.
Old 07-23-2014, 09:29 PM
would love too see a pic of the whole car actually :-)
Old 07-26-2014, 06:41 PM
Cobrakiller's Avatar
Have you had a look at how GM build the early model Corvettes? They have been building fiberglass bodies for over 60 years.Google C2 Corvette hood and see how they are made, 2 pieces top and bottom sections bonded together.Looking at your hood and front end I think that you will always have problems with sagging due to no support or reinforcement. Hope you can come up with a solution.
Old 07-26-2014, 08:06 PM
PeterAllen's Avatar
Many thanks, 'I love youse all'.
I'm optimistic I've identified and corrected the problem. It was not the bonnet but the original Datsun guard mounting points. In its forty years the car appears to have had a few knocks and not always been rebuilt to original specs. I've been all over the car with plum bobs and lasers to ensure the suspension pick-up points are all okay but I didn't even consider the body mounting points. In my defence I can only say that for the last thirty years I've been the only male in the household so logic and rational analysis have slipped from my skill base.
So, with the aid of a block of wood and an Irish screwdriver I have repositioned the mounting points on the tops of the inner guards. The guard lips now sit lower and align with the bonnet.
Cobrakiller - The kit did came with a fibreglass frame glued to the underside of the bonnet (and a similar concept on the boot {trunk} lid). I discarded them both as the whole thing was way too heavy. The fibreglassing on this particular kit is very thick, 3-5mm, and there is no gelcoat so I tend to think it was some kind of prototype. I don't know if this thickness is typical for road cars (?) but with the racing cars I owned and worked on (when I was single and had a life) the fibreglass was half, or less, that thickness but with strategically placed lips and ribs.
Rob. Smith likes this.
