Old 08-02-2014, 10:51 PM
Exclamation CV joint vs Uni Joint ?
Why can't I fabricate a drive/tailshaft by using CV Joints instead of a std Uni Joint
Rog 246
Harrison #100
Old 08-02-2014, 11:28 PM
Mrs flatchat's Avatar
Wink
You can-- just keep the angle to a minimum
Old 08-03-2014, 05:35 AM
joyridin''s Avatar
Why would you say that? The whole point of using a CV joint is the fact you can run reasonably hefty angles without running into binding problems.
Most of your serious off road 4wd racing vehicles all have CV joints. That is the only way they can get 24" of wheel travel.
Old 08-03-2014, 08:51 AM
Bob In Ct's Avatar
Universal joints produce rotational pulses when angles become too great. CV joints produce a more steady rotation. Thus the term "Constant Velocity".
Old 08-03-2014, 02:00 PM
Wink
The drive shaft to the diff is doing engine revs at 1:1 -- big angles makes lotsa heat
Old 08-07-2014, 09:41 PM
Jethrow's Avatar
Cobra Make, Engine: FFR Mk4 Roadster, LS3, TR6060, 8 3/4"
My driveshaft has a CV joint at the gearbox and a uni at the diff. Went that way because I was connecting a live axle to a gearbox with an output flange. Built by The Driveshaft Shop in USA.
Looks good.
Tim
FFR Mk4 Roadster
HSV Clubsport R8
Old 08-07-2014, 11:22 PM
DaveW's Avatar
Tim,
Have you got any pics?
I've done my tail shaft, but interested to see the CV version
regards
Dave
