14Likes
11-28-2014, 08:12 AM
Hey Zedn
sounds like you have air in you MC.
Try bleeding from the line fitting that connects to the end of MC.
Just crack fitting open while bleeding and bubble should disburse.
Once all air (bubbles) removed from master cylinder then move to slave cylinder and bleed from there.
Had same problem on mine and found this to be only way to remove air from Master cylinder
Reason: add more
11-28-2014, 02:13 PM
VIC
Originally Posted by DaveW
Sorry guys, bit sloppy on the description, try this
Dave - now I get it. Picture is worth a thousand words. As Guy said - Straight to the Pool Room :-)
11-28-2014, 03:18 PM
VIC
Love your work Dave
Mike Murphy
Melbourne Australia
11-28-2014, 03:45 PM
qld
love the drawing but ......... VB isn't that weed killer ,, or are you multi tasking
11-28-2014, 04:55 PM
VIC
Quick question - slightly related - Could you fit one of those bleed extension kits whilst the gearbox is attached to the engine (e.g. without separating them). Or would it be too messy and you would run the risk of fluid leaking into the bell housing? (or could you drain most of the fluid out first). Just trying to see if I could retrofit one without pulling engine gearbox apart. Curious only at this stage. Cheers Gregg
11-28-2014, 05:29 PM
VIC
you could probably fit one of mine but it'd be a pain in the ass job. If you were careful you could unscrew the original and screw the new extension in but it'd be hard to align and find the hole while working in the engine bay.
Lots of swearing probably required
Mike Murphy
Melbourne Australia
11-28-2014, 06:25 PM
NSW
Originally Posted by gjkrv8
...Could you fit one of those bleed extension kits whilst the gearbox is attached to the engine... Cheers Gregg
Not as supplied, but I believe you could by using it along with Mike's fitting.
I originally installed it as per the fitting instructions but following advice from experienced users I routed it up the firewall to ensure no air pocket existed.
11-28-2014, 10:34 PM
VIC
thanks Mike and Peter, I think I'll leave well enough alone until I have to bleed it again - fingers crossed that won't have to be for a while. cheers Gregg
12-01-2014, 11:18 PM
NSW
Hi Dave,
I have been looking on the net for a fish tank pump and also dropped into a pet store today. All the ones i have found have not had an air inlet on them. They seam to just have an outlet.
Is the Kmart one different? I tried on the Kmart website but couldn't find any listed. Havnt had a chance to drop into kmart yet.
12-02-2014, 12:24 AM
Vic
I know exactly the style of pump Dave is referring to, they were around and we had one when I was a kid, external, rectangular/squarish, beige body with a black base, hummed along with a small vibration, must admit I haven't seen one in over 25 years.
Maybe try your local aquarium shop to see different options?
Ben in AU
12-02-2014, 01:26 AM
NSW
I saw similar at the pet shop, but they only had an output. The instructions shower an internal diagram, but showed more of a large port than something you could put a hose on. Maybe I will just get the manual vacuum pump style for $30 off eBay.
12-02-2014, 02:04 AM
Vic
Zedn,
I'm in PNG at the moment, I texted my wife who found the box, its called a "Yuge F Mute Tank Aerator"
Made in china,
$10.99 from KMart.
Its in the pet toy section with water heaters and fish food.
Dave
Reason: bla
12-02-2014, 02:08 AM
Vic
Ben, yes thats exactly the description, except it has a grey plastic body now.
Although i did have one that was blue once.
When you switch it on it hums and will vibrate it self across the floor.
It is only 3 or 4 months ago that I last did this on my brothers vz ute, so they are still around.
Reason: who knows
12-02-2014, 03:01 AM
NSW
Cool thanks for going to the trouble. Much appreciated.
12-16-2014, 03:01 AM
NSW
I wasn't able to get a pump from Kmart so I bought a hand pump off eBay. Not the best quality but works none the less.
I bench bled the master cylinder tonight and this has given me some pedal feel but the clutch doesn't release.
When I vecuum the bleeder, it just sucks air. The bleed screw is really wobbly once it's undone. Even just a fraction of a turn and it wobbles from side to side. I think the vacuum is sucking air through the threads so not working. Is this normal?
I will try the conventional method now the master is done and see if to works that way. Should be less suseptable to air leaking in the thread.
12-16-2014, 03:27 AM
NSW
Cobra Make, Engine: have brakes, diff, gearbox, steering rack, gear stick, door locks, CR chassis 3518
Zedn, i have a couple of spare parts if you end up needing them, extension shaft and bleed nipple
03-05-2016, 04:20 PM
Vic
Old thread, but found this item on eBay which might help those coming up to bleeding a clutch, T56 ot TR6060 whatvere, or brakes in general.
Pneumatic AIR Brake Bleeder KIT Pressure Fluid Extractor With Fill Bottle SET | eBay
cheers
Dave
