Old 03-02-2015, 06:21 PM
Default dash covering
Have found some 3mm foam sheet from a company called Precision Foam in Windsor / Sydney after a bit of a search. Am looking at options for the top covering - vinyl, leather, carbon fiber adhesive sheet..??
Happy to take suggestions, pics and recommendations as well as the names of AU suppliers if possible..
With thanks
Chris
Old 03-03-2015, 03:21 PM
Cobra Make, Engine: Dax
3mm foam won't meet the ICV ADR head impact requirements in NSW.
Old 03-03-2015, 05:10 PM
Thanks Treeve.. is only for the larger panel areas.. have 20mm for the brow over the instruments.
Chris
Old 03-04-2015, 04:04 PM
from what I've worked out you need 26mm of the right density foam to meet the RTA requirements. It might be worth checking in with your engineer.
Old 03-05-2015, 03:13 PM
Yikes.. thanks Treeve... will follow it up.
Chris
