Old 03-17-2015, 09:52 PM
DaveW's Avatar
Cobra Make, Engine: Classic Revival CR3514, LS3, Dual Quads, Holley Dominator EFI, TR6060, VE 3.7 LSD, AP Racing Brakes, 17x8 & 10 Custom Dragway Billet Wheels.
Default Evap purge valve operation
Howdy Folks,
Anybody got the smarts on when the evap purge valve operates.
My valve is a combined Soloniod/valve unit, (standard GM LS3)
valve is normally closed,
Tested it and looks to be good, and doesnt leak when closed.
Obviously the ECU triggers it, but just interested what causes it to trigger, TPS, RPM or a combination.
Any thoughts?
Dave
http://cobra-cr3514.blogspot.com/
Old 03-18-2015, 12:23 AM
Gaz64's Avatar
The evaporative emission (EVAP) control system limits fuel vapors from escaping into the atmosphere. Fuel tank vapors are allowed to move from the fuel tank, due to pressure in the tank, through the vapor pipe, into the EVAP canister. Carbon in the canister absorbs and stores the fuel vapors. Excess pressure is vented through the vent pipe and EVAP air inlet to atmosphere. The EVAP canisters store the fuel vapors until the engine is able to use them. At an appropriate time, the control module will command the EVAP purge solenoid valve open, allowing engine vacuum to be applied to the EVAP canister. Fresh air will be drawn through the EVAP air inlet and vent pipe to the EVAP canisters. Fresh air is drawn through the EVAP canister, pulling fuel vapors from the carbon. The air/fuel vapor mixture continues through the EVAP purge pipe and EVAP purge solenoid valve into the intake manifold to be consumed during normal combustion.
EVAP Purge Solenoid Valve
The EVAP purge solenoid valve controls the flow of vapors from the EVAP system to the intake manifold. This normally closed valve is pulse width modulated (PWM) by the control module to precisely control the flow of fuel vapor to the engine.
The above is an excerpt from Holden SI.
GM programmers decide when the PWM is applied to the solenoid. Depends on engine temp, hot restart, hot idle, engine rpm, etc.
Gary
Old 03-18-2015, 03:30 AM
DaveW's Avatar
Thanks Gaz,
Its the last comment that im looking for, the triggers on when its open or closed.
Dave
